メインコンテンツにスキップ
Alienware 17 R3 Battery Replacement
必要な工具と部品
  1. Alienware 17 R3 Battery Replacement, Battery: 手順 1、 1の画像 1
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    購入する
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap to prevent any electrical shock to the components. Shocks may damage the components.
  2. Alienware 17 R3 Battery Replacement: 手順 2、 1の画像 1
    • Unscrew and remove the two 4mm Phillips #1 screws from the cover.
    • Remember to put the screws in a safe place so you can find them all during re-assembly.
  3. Alienware 17 R3 Battery Replacement: 手順 3、 1の画像 1
    • Pull up and slide the cover off.
  4. Alienware 17 R3 Battery Replacement: 手順 4、 2の画像 1 Alienware 17 R3 Battery Replacement: 手順 4、 2の画像 2
    • Unplug the black wire with the yellow tag to disconnect the battery.
  5. Alienware 17 R3 Battery Replacement: 手順 5、 2の画像 1 Alienware 17 R3 Battery Replacement: 手順 5、 2の画像 2
    • Unscrew and remove the four 3mm Phillips #1 screws holding the hard drive in place.
  6. Alienware 17 R3 Battery Replacement: 手順 6、 2の画像 1 Alienware 17 R3 Battery Replacement: 手順 6、 2の画像 2
    • Unscrew and remove the four 2mm Phillips #1 screws holding the casing together.
  7. Alienware 17 R3 Battery Replacement: 手順 7、 2の画像 1 Alienware 17 R3 Battery Replacement: 手順 7、 2の画像 2
    • Remove the plug from the hard drive.
    • Lift the hard drive out and set aside.
  8. Alienware 17 R3 Battery Replacement: 手順 8、 1の画像 1
    • Unscrew the one Phillips #1 screw holding down the bottom of the M.2 chip.
    • Pull the M.2 chip straight out of its socket.
  9. Alienware 17 R3 Battery Replacement: 手順 9、 1の画像 1
    • Unscrew and remove the eight 3mm Phillips #1 screws (located in areas labeled "P").
  10. Alienware 17 R3 Battery Replacement: 手順 10、 1の画像 1
    • Carefully disconnect the four flex cables.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
  11. Alienware 17 R3 Battery Replacement: 手順 11、 1の画像 1
    • Remove the six 4mm Phillips #1 screws on the side and the two 10mm Phillips #1 screws on the top.
  12. Alienware 17 R3 Battery Replacement: 手順 12、 1の画像 1
    • Flip over the laptop and open it.
    • Insert the spudger along the edges of the laptop and gently pry upward to lift the keyboard panel.
  13. Alienware 17 R3 Battery Replacement: 手順 13、 1の画像 1
    • Remove the six 4mm Phillips #1 screws holding the battery in place.
  14. Alienware 17 R3 Battery Replacement: 手順 14、 3の画像 1 Alienware 17 R3 Battery Replacement: 手順 14、 3の画像 2 Alienware 17 R3 Battery Replacement: 手順 14、 3の画像 3
    • Unplug the two sets of wires from the motherboard.
  15. Alienware 17 R3 Battery Replacement: 手順 15、 1の画像 1
    • Lift out the battery pack.
終わりに
20 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Jonathon Tschurwald
メンバー登録日: 02/01/17
830 ポイント
4のガイドは作成済み
チーム
UW Tacoma, Team 1-1, Rose Winter 2017 UW Tacoma, Team 1-1, Rose Winter 2017人のメンバー
UWT-ROSE-W17S1G1
3 メンバー
5のガイドは作成済み
5 件のコメント
Hi ! Nice DIY . Is it possible to disassemble the battery pack and change the cell inside ?
francois tremblay - 返信
Hi, please edit step 10. There a 4th ribbon has to be pulled.
Nevertheless a very good manual.
Steffen Bönisch - 返信
Hi Steffen,
Thanks for the tip! I edited step 10 to correct the mistake.
Arthur Shi -
Very helpful and concise. Worked very well for me. Many Thanks
Ragufta Khan - 返信
After putting everything back together I found my didn't HDD work. It was simply that the other end of the HDD cable had become disconnected.
I'd recommend disconnecting this before removing the HDD housing so it doesn't snag (it's actually shown as disconnected in step 10).
Dom Parrott - 返信
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 59
過去 30 日: 223
今までの合計 33,047
