メインコンテンツにスキップ
はじめに
In this guide, we will be showing you how to remove and replace the Memory Modules.
パーツ
パーツは指定されていません。
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the base panel.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  2. Slide and remove the memory module from the memory-module slot. Slide and remove the memory module from the memory-module slot.
    • Slide and remove the memory module from the memory-module slot.
  3. Align the notch on the new memory module with the tab on the memory- module slot.
    • Align the notch on the new memory module with the tab on the memory- module slot.
  4. Slide the memory module firmly into the slot at an angle and press the  memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • If you do not hear the click, remove the memory module and reinstall it.
終わりに
Terrence15
メンバー登録日: 2017年12月18日
73,108 ポイント
442のガイドは作成済み
チーム
Informative Technologies Inc. Informative Technologies Inc.人のメンバー
Community
38 メンバー
1,973のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 260
