メインコンテンツにスキップ
Alienware 15 R2 Fan Replacement
必要な工具と部品
  1. Alienware 15 R2 Fan Replacement, RAM: 手順 1、 3の画像 1 Alienware 15 R2 Fan Replacement, RAM: 手順 1、 3の画像 2 Alienware 15 R2 Fan Replacement, RAM: 手順 1、 3の画像 3
    • Place laptop upside down with the hinge facing you, then remove the two 9mm Phillips #0 screws located in the bottom left and right of the of the rear panel.
    • Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
  2. Alienware 15 R2 Fan Replacement: 手順 2、 2の画像 1 Alienware 15 R2 Fan Replacement: 手順 2、 2の画像 2
    • Use the iFixit opening tool to disconnect the battery cable. Put the iFixit tool underneath the cable and then pull it to remove.
  3. Alienware 15 R2 Fan Replacement: 手順 3、 2の画像 1 Alienware 15 R2 Fan Replacement: 手順 3、 2の画像 2
    • Find the RAM located near the edge of the computer closest to you. Locate the small latches on either side of the RAM stick and push in the two latches to release. Gently grasp the RAM stick on either side and pull straight out. Repeat for the second RAM stick.
  4. Alienware 15 R2 Fan Replacement, Fan: 手順 4、 2の画像 1 Alienware 15 R2 Fan Replacement, Fan: 手順 4、 2の画像 2
    • In the center of the RAM card, remove the 9 mm screw using the Phillips #0 screwdriver.
  5. Alienware 15 R2 Fan Replacement: 手順 5、 2の画像 1 Alienware 15 R2 Fan Replacement: 手順 5、 2の画像 2
    • Remove all screws from the back casing. (4X 18mm, 4X 10mm, 4X 6mm)
    • Press your finger in the hole next to the hard drive to lift the keyboard up.
  6. Alienware 15 R2 Fan Replacement: 手順 6、 1の画像 1
    • Disconnect the fan wires.
  7. Alienware 15 R2 Fan Replacement: 手順 7、 3の画像 1 Alienware 15 R2 Fan Replacement: 手順 7、 3の画像 2 Alienware 15 R2 Fan Replacement: 手順 7、 3の画像 3
    • If you're replacing the fans, remove the three 6.0 mm screws from the fan and pull the fans out. (The orange circle shows where a screw will already be removed). If you're cleaning the fans, use compressed air to clean the blades and air duct.
終わりに
作成者
6人の作成者と共同で作成されました。
Nathaniel Evans
メンバー登録日: 09/18/19
417 ポイント
3のガイドは作成済み
チーム
Western Carolina University, Team S1-G2, Virtue Fall 2019 Western Carolina University, Team S1-G2, Virtue Fall 2019人のメンバー
WCU-VIRTUE-F19S1G2
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 35
今までの合計 2,601
