メインコンテンツにスキップ
Alienware 15 R2 Battery Replacement
必要な工具と部品
  1. Alienware 15 R2 Battery Replacement, RAM: 手順 1、 3の画像 1 Alienware 15 R2 Battery Replacement, RAM: 手順 1、 3の画像 2 Alienware 15 R2 Battery Replacement, RAM: 手順 1、 3の画像 3
    • Place laptop upside down with the hinge facing you, then remove the two 9mm Phillips #0 screws located in the bottom left and right of the of the rear panel.
    • Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
  2. Alienware 15 R2 Battery Replacement: 手順 2、 2の画像 1 Alienware 15 R2 Battery Replacement: 手順 2、 2の画像 2
    • Use the iFixit opening tool to disconnect the battery cable. Put the iFixit tool underneath the cable and then pull it to remove.
  3. Alienware 15 R2 Battery Replacement: 手順 3、 2の画像 1 Alienware 15 R2 Battery Replacement: 手順 3、 2の画像 2
    • Find the RAM located near the edge of the computer closest to you. Locate the small latches on either side of the RAM stick and push in the two latches to release. Gently grasp the RAM stick on either side and pull straight out. Repeat for the second RAM stick.
  4. Alienware 15 R2 Battery Replacement, Battery: 手順 4、 2の画像 1 Alienware 15 R2 Battery Replacement, Battery: 手順 4、 2の画像 2
    • Using a Phillips #0 remove the small 1X 3mm screw behind where the RAM used to be.
  5. Alienware 15 R2 Battery Replacement: 手順 5、 1の画像 1
    • Remove all screws from the back casing. (4X 18mm, 4X 10mm, 4X 6mm)
    • Press your finger in the hole next to the hard drive to lift the key board.
  6. Alienware 15 R2 Battery Replacement: 手順 6、 1の画像 1
    • Disconnect and move aside the left and right wires.
  7. Alienware 15 R2 Battery Replacement: 手順 7、 2の画像 1 Alienware 15 R2 Battery Replacement: 手順 7、 2の画像 2
    • Using a Phillips #0 remove the screws holding the battery in. (3X 6mm)
    • You may also remove the ribbon cables on the bottom of the laptop to gain more room to work. (This is not required)
  8. Alienware 15 R2 Battery Replacement: 手順 8、 1の画像 1
    • Remove the red, white, blue, and black colored wires connected to the motherboard.
  9. Alienware 15 R2 Battery Replacement: 手順 9、 1の画像 1
    • Lift the battery from the front edge and remove.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Nathaniel Evans
メンバー登録日: 09/18/19
417 ポイント
3のガイドは作成済み
チーム
Western Carolina University, Team S1-G2, Virtue Fall 2019 Western Carolina University, Team S1-G2, Virtue Fall 2019人のメンバー
WCU-VIRTUE-F19S1G2
4 メンバー
7のガイドは作成済み
コメント 1 件
Honestly made an account to comment on this repair guide, this is extremely incomplete. I’d go as far as saying you’re likely to damage the product by relying solely on this guide, I would turn to a breakdown on YouTube instead. I’m not sure if this is listed under the correct product.
mdumtshali - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 32
過去 30 日: 152
今までの合計 9,786
