はじめに
If your front facing camera just isn't taking good pictures anymore then it might be time to replace it! This guide will show you how to replace your camera in just a few simple steps. You'll have to remove the the first and secondary covers to get to the motherboard. Then you'll have to disengage the connectors to the motherboard so that you can remove it and access the front camera.
必要な工具と部品
Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
Slide the ribbon cable out of the socket.
