メインコンテンツにスキップ
Alcatel OneTouch Pop Icon Motherboard Replacement
必要な工具と部品
  1. Alcatel OneTouch Pop Icon Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Shut down the device
    • Flip the phone so that the screen is facing the surface you are working on
    • Aggressive prying may result in damaging the back panel or the internal contents of the phone.
    • Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
  2. Alcatel OneTouch Pop Icon Motherboard Replacement: 手順 2、 2の画像 1 Alcatel OneTouch Pop Icon Motherboard Replacement: 手順 2、 2の画像 2
    • Use your thumbnail to lift the battery from the phone.
  3. Alcatel OneTouch Pop Icon Motherboard Replacement, Interior Back Panel: 手順 3、 1の画像 1
    • Using the J000 Phillips screwdriver, remove the twelve silver 3mm screws.
    • Using the J000 Phillips screwdriver, remove the one green 3mm screw.
  4. Alcatel OneTouch Pop Icon Motherboard Replacement: 手順 4、 1の画像 1
    • With the screen facing you and the front facing camera to your right, insert the plastic opening tool between the screen and the interior back panel and gently pry it off.
    • Make sure all of the clips come undone when you pry the seam loose.
  5. Alcatel OneTouch Pop Icon Motherboard Replacement, Control Buttons: 手順 5、 1の画像 1
    • Lift the latch and gently remove the ribbon from the latch.
  6. Alcatel OneTouch Pop Icon Motherboard Replacement: 手順 6、 2の画像 1 Alcatel OneTouch Pop Icon Motherboard Replacement: 手順 6、 2の画像 2
    • Use the metal spudger to gently pry the control buttons from the case.
    • The control buttons are glued to the case and are on a computer ribbon. When removing them it is best to move between them so as to avoid damaging them.
    • Make sure to use a plastic opening tool or nylon spudger before attempting to use a metal spudger. Metal spudgers can potentially damage your device.
  7. Alcatel OneTouch Pop Icon Motherboard Replacement, Motherboard: 手順 7、 3の画像 1 Alcatel OneTouch Pop Icon Motherboard Replacement, Motherboard: 手順 7、 3の画像 2 Alcatel OneTouch Pop Icon Motherboard Replacement, Motherboard: 手順 7、 3の画像 3
    この手順で使用する道具:
    購入する
    • Using tweezers, carefully detach the antenna from the motherboard.
  8. Alcatel OneTouch Pop Icon Motherboard Replacement: 手順 8、 3の画像 1 Alcatel OneTouch Pop Icon Motherboard Replacement: 手順 8、 3の画像 2 Alcatel OneTouch Pop Icon Motherboard Replacement: 手順 8、 3の画像 3
    • Remove the tape on top of the ribbon.
    • Lift the black latch to release the ribbon.
    • Remove the ribbon from the latch.
  9. Alcatel OneTouch Pop Icon Motherboard Replacement: 手順 9、 1の画像 1
    • Lift the tab from the casing.
  10. Alcatel OneTouch Pop Icon Motherboard Replacement: 手順 10、 3の画像 1 Alcatel OneTouch Pop Icon Motherboard Replacement: 手順 10、 3の画像 2 Alcatel OneTouch Pop Icon Motherboard Replacement: 手順 10、 3の画像 3
    • Use the tweezers to remove tape the from the top of the latch. Still using the tweezers, lift the black latch to release the ribbon.
  11. Alcatel OneTouch Pop Icon Motherboard Replacement: 手順 11、 1の画像 1
    • Remove the motherboard from the casing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
John Halsey
メンバー登録日: 04/01/16
1,000 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 2-2, Andersen Spring 2016 Eastern Washington University, Team 2-2, Andersen Spring 2016人のメンバー
EWU-ANDERSEN-S16S2G2
5 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 1,987
