この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Replacing the control buttons is a moderately difficult process that is best done if you are comfortable working with the internal components of electronics. Make sure, that when using the metal spudger that may cause electrostatic discharge, to ground yourself by touching a metal object before using the spudger.
必要な工具と部品
Shut down the device
Flip the phone so that the screen is facing the surface you are working on
Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
Using the J000 Phillips screwdriver, remove the twelve silver 3mm screws.
Using the J000 Phillips screwdriver, remove the one green 3mm screw.
