メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Alcatel OneTouch Pop Icon Camera Replacement
必要な工具と部品
  1. Alcatel OneTouch Pop Icon Camera Replacement, Battery: 手順 1、 1の画像 1
    • Shut down the device
    • Flip the phone so that the screen is facing the surface you are working on
    • Aggressive prying may result in damaging the back panel or the internal contents of the phone.
    • Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
  2. Alcatel OneTouch Pop Icon Camera Replacement: 手順 2、 2の画像 1 Alcatel OneTouch Pop Icon Camera Replacement: 手順 2、 2の画像 2
    • Use your thumbnail to lift the battery from the phone.
  3. Alcatel OneTouch Pop Icon Camera Replacement, Interior Back Panel: 手順 3、 1の画像 1
    • Using the J000 Phillips screwdriver, remove the twelve silver 3mm screws.
    • Using the J000 Phillips screwdriver, remove the one green 3mm screw.
  4. Alcatel OneTouch Pop Icon Camera Replacement: 手順 4、 1の画像 1
    • With the screen facing you and the front facing camera to your right, insert the plastic opening tool between the screen and the interior back panel and gently pry it off.
    • Make sure all of the clips come undone when you pry the seam loose.
  5. Alcatel OneTouch Pop Icon Camera Replacement, Camera: 手順 5、 1の画像 1
    この手順で使用する道具:
    • Use tweezers to gently lift the tab free from the motherboard.
  6. Alcatel OneTouch Pop Icon Camera Replacement: 手順 6、 1の画像 1
    • Gently lift the camera away from the motherboard.
終わりに
作成者
5人の作成者と共同で作成されました。
John Halsey
メンバー登録日: 04/01/16
1,000 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 2-2, Andersen Spring 2016 Eastern Washington University, Team 2-2, Andersen Spring 2016人のメンバー
EWU-ANDERSEN-S16S2G2
5 メンバー
14のガイドは作成済み
3件のガイドコメント
Hi I just noticed last night that the lense cover for my camera has fallen off any ideas on how to replace it?
Phoeras Mortisangelina - 返信
Do we put a new camera or that old one
Sareen Lata - 返信
Urgently needed
Sareen Lata - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 33
今までの合計 928
