この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Removing the battery is a quick and simple operation that will occasionally be needed in order to troubleshoot the phone.
必要な工具と部品
Shut down the device
Flip the phone so that the screen is facing the surface you are working on
Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
2 の人々がこのガイドを完成させました。
