メインコンテンツにスキップ
Alcatel OneTouch Evolve Secondary Panel Removal
必要な工具と部品
  1. Alcatel OneTouch Evolve Secondary Panel Removal, Locate the access tab: 手順 1、 1の画像 1
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
  2. Alcatel OneTouch Evolve Secondary Panel Removal, Place the flat head end of the pry tool into the tab: 手順 2、 3の画像 1 Alcatel OneTouch Evolve Secondary Panel Removal, Place the flat head end of the pry tool into the tab: 手順 2、 3の画像 2 Alcatel OneTouch Evolve Secondary Panel Removal, Place the flat head end of the pry tool into the tab: 手順 2、 3の画像 3
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
  3. Alcatel OneTouch Evolve Secondary Panel Removal, Identify the Battery: 手順 3、 1の画像 1
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
  4. Alcatel OneTouch Evolve Secondary Panel Removal, Removing the battery: 手順 4、 2の画像 1 Alcatel OneTouch Evolve Secondary Panel Removal, Removing the battery: 手順 4、 2の画像 2
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
  5. Alcatel OneTouch Evolve Secondary Panel Removal, Locate Screws Holding the Secondary Panel in Place: 手順 5、 1の画像 1
    • There will be eight 4.5mm screws that fit your Phillips head PH00 screwdriver notated by the red circles in the image.
  6. Alcatel OneTouch Evolve Secondary Panel Removal, Remove Screws: 手順 6、 1の画像 1
    この手順で使用する道具:
    購入する
    • Unscrew each screw, counter-clockwise (left), until each one has been removed.
    • If necessary, use tweezers to fully remove the screws from the device.
    • Remove battery before lifting off the panel.
  7. Alcatel OneTouch Evolve Secondary Panel Removal, Prying the Panel Off: 手順 7、 3の画像 1 Alcatel OneTouch Evolve Secondary Panel Removal, Prying the Panel Off: 手順 7、 3の画像 2 Alcatel OneTouch Evolve Secondary Panel Removal, Prying the Panel Off: 手順 7、 3の画像 3
    • Access the small pry tool in the tool kit
    • Place flat head in the crease between the phone and panel where the matte finish meets the shiny finish of the front of the phone.
    • Rotate the pry tool 90 degrees until part of the panel lifts up
    • All areas need to be fully risen off before the panel can be removed.
    • Do not use the opening tool to pry open the device near the power button or near the volume button.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Brendan Egan
メンバー登録日: 10/28/14
2,467 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 4-5, Miles Fall 2014 UMass Dartmouth, Team 4-5, Miles Fall 2014人のメンバー
UMASSD-MILES-F14S4G5
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 15
今までの合計 2,090
