はじめに
If you are experiencing a problem connecting to either WIFI or cellular data, you could have a faulty WIFI antenna. This guide will show you the simple steps to replace it.
必要な工具と部品
Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
この手順で使用する道具:Tweezers$4.99
Using the tweezers, pull the WIFI Antenna away from the motherboard and the wireless card.
ある他の人がこのガイドを完成しました。
