メインコンテンツにスキップ
Alcatel One Touch Pop 7 Volume Button Assembly Replacement
必要な工具と部品
  1. Alcatel One Touch Pop 7 Volume Button Assembly Replacement, Volume Button Assembly: 手順 1、 1の画像 1
    • Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
  2. Alcatel One Touch Pop 7 Volume Button Assembly Replacement: 手順 2、 3の画像 1 Alcatel One Touch Pop 7 Volume Button Assembly Replacement: 手順 2、 3の画像 2 Alcatel One Touch Pop 7 Volume Button Assembly Replacement: 手順 2、 3の画像 3
    この手順で使用する道具:
    • With the back cover removed you will now want to disconnect the battery. Use the tweezers and gently pull the wires as shown in the second picture.
  3. Alcatel One Touch Pop 7 Volume Button Assembly Replacement: 手順 3、 2の画像 1 Alcatel One Touch Pop 7 Volume Button Assembly Replacement: 手順 3、 2の画像 2
    • The volume button assembly is in the top left corner of the tablet. To begin, you will have to pull the small black tab of the ZIF connector, shown in the second picture, to be able to remove the assembly. The tab is on a hinge so it should not be pulled off completely.
  4. Alcatel One Touch Pop 7 Volume Button Assembly Replacement: 手順 4、 3の画像 1 Alcatel One Touch Pop 7 Volume Button Assembly Replacement: 手順 4、 3の画像 2 Alcatel One Touch Pop 7 Volume Button Assembly Replacement: 手順 4、 3の画像 3
    • Pull the copper ribbon cable from the tab. It should be easily removed, as the ZIF connector is the only thing holding it in place.
    • Next up is removing the volume button assembly. Another easy removal, simply pull the assembly away from the device and you're done with the removal process.
終わりに
To reassemble your device, follow these instructions in reverse order with the new volume button assembly replacing the old one.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Riley Cooper
メンバー登録日: 10/10/16
926 ポイント
5のガイドは作成済み
チーム
Sam Houston State, Team 12-1, Blackburne Fall 2016 Sam Houston State, Team 12-1, Blackburne Fall 2016人のメンバー
SHSU-BLACKBURNE-F16S12G1
3 メンバー
10のガイドは作成済み
0 Guide Comments
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 17
今までの合計 1,023
