メインコンテンツにスキップ
はじめに
In the case that your device is not producing any sound, it may be necessary to replace the speaker completely. This guide shows you where the speaker is within your device and how to replace it!
パーツ
パーツは指定されていません。
  1. Begin by opening SD port cover as this is the best location to start prying.
    • Begin by opening SD port cover as this is the best location to start prying.
  2. Use the plastic opening tool to pry around the edges of the back cover until it pops off.
    • Use the plastic opening tool to pry around the edges of the back cover until it pops off.
  3. Locate the speaker on the bottom left hand  side of the back cover.
    • Locate the speaker on the bottom left hand side of the back cover.
  4. Using the plastic opening tool, dig under the silver speaker to remove it from the back cover. Using the plastic opening tool, dig under the silver speaker to remove it from the back cover.
    • Using the plastic opening tool, dig under the silver speaker to remove it from the back cover.
まとめ
Libby West
メンバー登録日: 2018年03月20日
85 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S6-G2, Baechle Spring 2018 IUPUI, Team S6-G2, Baechle Spring 2018人のメンバー
IUPUI-BAECHLE-S18S6G2
3 メンバー
4のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 85
