メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
In this guide you will be shown how to effectively replace the front camera on your device.
  1. Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone. Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Remove the 11 Phillips #000 screws. The midframe should lift free. The midframe should lift free.
    • Remove the 11 Phillips #000 screws.
    • The midframe should lift free.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Use the tip of a spudger to pull back the yellow tape covering the battery connector. Use a pair of tweezers to pull the battery connector from its port.
    • Use the tip of a spudger to pull back the yellow tape covering the battery connector.
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
  5. Carefully remove the motherboard from the rest of the phone.
    • Carefully remove the motherboard from the rest of the phone.
  6. Use a pair of tweezers to disconnect and remove the front facing camera from the motherboard. Use a pair of tweezers to disconnect and remove the front facing camera from the motherboard.
    • Use a pair of tweezers to disconnect and remove the front facing camera from the motherboard.
終わりに
5 の人々がこのガイドを完成させました。
Rijkaard Thomas
メンバー登録日: 2014年10月22日
99 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 5-5, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-5, Vijaybhaskar Fall 2014人のメンバー
UMASSD-VIJAYBHASKAR-F14S5G5
3 メンバー
3のガイドは作成済み
2 件のコメント
tenx tenx tenx !!?
ismail - 返信
I paid for a phone to capture precious moments, & the pictures are horrible, how can this be fixed??? This is wrong on all levels, I feel that we should be able to try any phone out before purchasing, so we know what we are buying, I'm returning my phone & wouldn't recommend this brand to anyone.
Jeanne Edenfield - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 6,316
