メインコンテンツにスキップ
Alcatel One Touch Fierce Battery Replacement
必要な工具と部品
  1. Alcatel One Touch Fierce Battery Replacement, Rear Case: 手順 1、 2の画像 1 Alcatel One Touch Fierce Battery Replacement, Rear Case: 手順 1、 2の画像 2
    • Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Alcatel One Touch Fierce Battery Replacement, Midframe: 手順 2、 3の画像 1 Alcatel One Touch Fierce Battery Replacement, Midframe: 手順 2、 3の画像 2 Alcatel One Touch Fierce Battery Replacement, Midframe: 手順 2、 3の画像 3
    • Remove the 11 Phillips #000 screws.
    • The midframe should lift free.
  3. Alcatel One Touch Fierce Battery Replacement, Battery: 手順 3、 2の画像 1 Alcatel One Touch Fierce Battery Replacement, Battery: 手順 3、 2の画像 2
    • Use the tip of a spudger to pull back the yellow tape covering the battery connector.
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
終わりに
23 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jonathan Ruiz
メンバー登録日: 12/13/11
1,322 ポイント
2のガイドは作成済み
6 件のコメント
Hello.. please suggest how to remove battery of one touch FLASH.
It is non removable battery.. Since my mobile is unable to reboot I need to remove back cover to make it work
Kapil Chaudhari - 返信
remove sd and sim cards with power off…same as fierce 4/pop 4 all Phillips 000 screws come out then carefully unsnap inner back case half from main case starting on opposite side of power button.with each snap undone, carefully pry case half’s apart using plastic tool or credit card. once apart, unfasten battery connector. power up phone before re assembly.once it works power off and reverse instructions to assemble.
john vanlandingham - 返信
If the battery is so easy to remove, why is it called “non-removable”?
fbanks47 - 返信
how do you reboot after battery replacement
Alan Duncan - 返信
How do I transfer google files from my alcotel phone to my computer
Alan Duncan - 返信
When removing the battery connector on the 5054N model its best to gently lift one side of the battery up a little then the other at the opposite end of the battery connector and then gently rock side to side as you gently raise the battery up.
The battery connector wires are somewhat stiff and rocking the battery side to side while gently lifting upward will dislodge the battery connector.
When replacing the battery connector make sure to gently put the battery back in its place in the phone and then place the connector in position and gently push until you hear or more likely feel the light pop of a snap connector.
When the battery connector is sitting flush then you know its connected.
Do not try to force with extra pressure. gently push down on the connector and gauge whether the force you’re using is enough to safely connect the battery connector. If not then look to see if it needs to be repositioned. If it doesnt need to be then apply a minuet amount of pressure more until you feel it snap in place.
Bren Foster - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 39
今までの合計 74,551
