はじめに
A very easy guide showing you how to replace the battery on this phone.
必要な工具と部品
Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone.
Lift the rear case by the corner nearest the divot and remove it from the phone.
Use the tip of a spudger to pull back the yellow tape covering the battery connector.
Use a pair of tweezers to pull the battery connector from its port.
23 の人々がこのガイドを完成させました。
6 件のコメント
Hello.. please suggest how to remove battery of one touch FLASH.
It is non removable battery.. Since my mobile is unable to reboot I need to remove back cover to make it work
remove sd and sim cards with power off…same as fierce 4/pop 4 all Phillips 000 screws come out then carefully unsnap inner back case half from main case starting on opposite side of power button.with each snap undone, carefully pry case half’s apart using plastic tool or credit card. once apart, unfasten battery connector. power up phone before re assembly.once it works power off and reverse instructions to assemble.
how do you reboot after battery replacement
How do I transfer google files from my alcotel phone to my computer
