メインコンテンツにスキップ
Alcatel OT-208 battery troubleshooting
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
  1. Alcatel OT-208 battery troubleshooting, Locate the Battery: 手順 1、 3の画像 1 Alcatel OT-208 battery troubleshooting, Locate the Battery: 手順 1、 3の画像 2 Alcatel OT-208 battery troubleshooting, Locate the Battery: 手順 1、 3の画像 3
    • On the back of the phone there is a black panel
    • Near the bottom left corner of the panel there is an arrow and an indentation.
    • This is where you will pull off the black panel.
    • Underneath is the battery. There is a groove in the red plastic just above the battery.
    • Use this groove to pull out the battery. When you are ready to put the battery back in, it must be placed the way it was when you took it out.
  2. Alcatel OT-208 battery troubleshooting, Test the battery: 手順 2、 1の画像 1
    • Make sure it is inserted properly. There are two indicators that it is correct. The remove arrow is on the front and point up; and the gold plates on the bottom match the gold prongs on the device.
    • Make sure the battery is inserted before placing the device on a charger.
    • Make sure it is completely dead before placing it on the charger. There is a battery icon on the top of the screen. When it is empty, the battery is dead.
    • The best way to get maximum use out of your battery make sure you are using an Alcatel battery and charger.
    • If the charger is the problem, check your outlets first.
    • If you put the charger in the port and it flashes on for a second and then stops charging, the charger is the problem.
    • If this is the case, go ahead and order a new charger.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Marie Rolston
メンバー登録日: 09/01/14
537 ポイント
4のガイドは作成済み
チーム
USF Sarasota-Manatee, Team 1-3, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-3, Stewart Fall 2014人のメンバー
USFSM-STEWART-F14S1G3
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 274
