メインコンテンツにスキップ
Alcatel IdealXCITE Rear Speaker Replacement
必要な工具と部品
  1. Alcatel IdealXCITE Rear Speaker Replacement, Battery: 手順 1、 3の画像 1 Alcatel IdealXCITE Rear Speaker Replacement, Battery: 手順 1、 3の画像 2 Alcatel IdealXCITE Rear Speaker Replacement, Battery: 手順 1、 3の画像 3
    • Place your finger in the small notch on the left corner of the phone.
    • Use your finger to gently pull up on the back cover where the notch is located.
    • Gently pull up on the back cover, working around the phone.
    • Remove the cover from the phone, and set it aside for later installation.
  2. Alcatel IdealXCITE Rear Speaker Replacement: 手順 2、 3の画像 1 Alcatel IdealXCITE Rear Speaker Replacement: 手順 2、 3の画像 2 Alcatel IdealXCITE Rear Speaker Replacement: 手順 2、 3の画像 3
    • Place your thumb in the small notch between the battery and the phone.
    • Use your thumb to gently pry the battery up at the notch, releasing it from the phone.
    • Take note of the contacts in the phone and on the battery for reinstallation.
  3. Alcatel IdealXCITE Rear Speaker Replacement, Antenna: 手順 3、 2の画像 1 Alcatel IdealXCITE Rear Speaker Replacement, Antenna: 手順 3、 2の画像 2
    • Remove the four 4mm PH00 screws.
  4. Alcatel IdealXCITE Rear Speaker Replacement: 手順 4、 3の画像 1 Alcatel IdealXCITE Rear Speaker Replacement: 手順 4、 3の画像 2 Alcatel IdealXCITE Rear Speaker Replacement: 手順 4、 3の画像 3
    • Using a spudger, pry upwards in the indentation on the bottom right corner of the phone.
    • Work the tool gently around the antenna to release it.
  5. Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: 手順 5、 3の画像 1 Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: 手順 5、 3の画像 2 Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: 手順 5、 3の画像 3
    • Remove the three 4mm PH00 screws holding the WiFi/GPS antenna in.
    • Gently pry the WiFi/GPS antenna out using a Jimmy and set aside.
  6. Alcatel IdealXCITE Rear Speaker Replacement: 手順 6、 2の画像 1 Alcatel IdealXCITE Rear Speaker Replacement: 手順 6、 2の画像 2
    • Remove the three remaining 4mm PH00 screws.
    • Remove the two 3mm PH00 screws.
  7. Alcatel IdealXCITE Rear Speaker Replacement: 手順 7、 3の画像 1 Alcatel IdealXCITE Rear Speaker Replacement: 手順 7、 3の画像 2 Alcatel IdealXCITE Rear Speaker Replacement: 手順 7、 3の画像 3
    • Using a spudger and an iFixit opening pick, pry the midframe up.
  8. Alcatel IdealXCITE Rear Speaker Replacement: 手順 8、 3の画像 1 Alcatel IdealXCITE Rear Speaker Replacement: 手順 8、 3の画像 2 Alcatel IdealXCITE Rear Speaker Replacement: 手順 8、 3の画像 3
    • Pry gently between the rear case and speaker using an iFixit opening pick.
    • Reapply adhesive to the new speaker when reassembling the phone.
終わりに
作成者
2人の作成者と共同で作成されました。
Franklin Froehlich
メンバー登録日: 03/07/19
427 ポイント
3のガイドは作成済み
チーム
Casper College, Team S1-G2, Lareau Spring 2019 Casper College, Team S1-G2, Lareau Spring 2019人のメンバー
CASC-LAREAU-S19S1G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 4
今までの合計 328
