はじめに
This guide will help you remove the front panel of your Akaso EK7000. You will need a metal spudger or any other tool for prying and separating.
必要な工具と部品
Locate the battery cover at the bottom of the camera. Use your fingers to gently pry open the battery cover.
Using the metal spudger, gently pry open the front panel from the exposed battery cartridge.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
