メインコンテンツにスキップ
Akai MPK25 Volume Knob / Pitch Bender Replacement
必要な工具と部品
  1. Akai MPK25 Volume Knob / Pitch Bender Replacement, Face Plate: 手順 1、 1の画像 1
    • Remove all the selector knob covers by pulling them off.
  2. Akai MPK25 Volume Knob / Pitch Bender Replacement: 手順 2、 1の画像 1
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
  3. Akai MPK25 Volume Knob / Pitch Bender Replacement: 手順 3、 1の画像 1
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Akai MPK25 Volume Knob / Pitch Bender Replacement: 手順 4、 3の画像 1 Akai MPK25 Volume Knob / Pitch Bender Replacement: 手順 4、 3の画像 2 Akai MPK25 Volume Knob / Pitch Bender Replacement: 手順 4、 3の画像 3
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Akai MPK25 Volume Knob / Pitch Bender Replacement: 手順 5、 3の画像 1 Akai MPK25 Volume Knob / Pitch Bender Replacement: 手順 5、 3の画像 2 Akai MPK25 Volume Knob / Pitch Bender Replacement: 手順 5、 3の画像 3
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
  6. Akai MPK25 Volume Knob / Pitch Bender Replacement, Volume Knob / Pitch Bender: 手順 6、 1の画像 1
    • Rotate the device 180 degrees, so that the motherboard is closest to you.
    • Take caution to not damage the ribbon cable connecting the face plate to the chassis.
    • Remove the ribbon cable connecting the knobs to the mother board by gently wiggling and pulling it away from the motherboard.
  7. Akai MPK25 Volume Knob / Pitch Bender Replacement: 手順 7、 2の画像 1 Akai MPK25 Volume Knob / Pitch Bender Replacement: 手順 7、 2の画像 2
    • Using a Phillips #2 screwdriver, remove the four 9.5 mm silver screws holding the knobs to the face plate.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Serbinder Singh
メンバー登録日: 01/30/13
81 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 20-6, Maness Winter 2013 Cal Poly, Team 20-6, Maness Winter 2013人のメンバー
CPSU-MANESS-W13S20G6
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 2,538
