メインコンテンツにスキップ
AirPods Charging Case Battery Replacement
必要な工具と部品
ビデオの概要
  1. AirPods Charging Case Battery Replacement, AirPods charging case battery replacement: 手順 1、 2の画像 1 AirPods Charging Case Battery Replacement, AirPods charging case battery replacement: 手順 1、 2の画像 2
    • It is difficult to teardown the AirPods charging case because the charging case features 2 fixed points and the middle part is glued with adhesive. The charging case can easily be damaged by careless methods of dissasembly.
  2. AirPods Charging Case Battery Replacement, Creating a pry tool: 手順 2、 3の画像 1 AirPods Charging Case Battery Replacement, Creating a pry tool: 手順 2、 3の画像 2 AirPods Charging Case Battery Replacement, Creating a pry tool: 手順 2、 3の画像 3
    • There is currently no special repair tool for the AirPods. Therefore, we need to make a set of disassembly tools.
    • Be careful when handling sharp and thin metal as it can easily injure your hands.
    • Make a pry piece with a 0.1mm steel plate. Firstly, cut the steel plate into the shape of a pry piece with a pair of scissors.
    • Grind the edges of the pry piece with a sheet of sandpaper.
  3. AirPods Charging Case Battery Replacement, Preparing the pry tool: 手順 3、 2の画像 1 AirPods Charging Case Battery Replacement, Preparing the pry tool: 手順 3、 2の画像 2
    • Bend the pry piece with a cutting nipper.
    • Use tweezers to make a shielding plate.
  4. AirPods Charging Case Battery Replacement, Prepare for opening the case: 手順 4、 3の画像 1 AirPods Charging Case Battery Replacement, Prepare for opening the case: 手順 4、 3の画像 2 AirPods Charging Case Battery Replacement, Prepare for opening the case: 手順 4、 3の画像 3
    • To avoid damaging the charging case, wrap high-temperature tape around it.
    • Next, insert the pry piece into the seam of the two fixed points.
    • Use the pry knife to pry out a gap.
  5. AirPods Charging Case Battery Replacement, Start opening case: 手順 5、 2の画像 1 AirPods Charging Case Battery Replacement, Start opening case: 手順 5、 2の画像 2
    • Insert the shielding plate.
    • Insert the tweezers.
  6. AirPods Charging Case Battery Replacement, Removing the docking tubes: 手順 6、 2の画像 1 AirPods Charging Case Battery Replacement, Removing the docking tubes: 手順 6、 2の画像 2
    • Wedge the special pry piece into the seam to pull out the docking tubes.
    • Please do not damage the flex cable while pulling out.
  7. AirPods Charging Case Battery Replacement, Remove the old battery: 手順 7、 3の画像 1 AirPods Charging Case Battery Replacement, Remove the old battery: 手順 7、 3の画像 2 AirPods Charging Case Battery Replacement, Remove the old battery: 手順 7、 3の画像 3
    • Attach the charging case to the holder and dip a small amount of alcohol on the battery.
    • Pry up the battery with the pry knife and the battery connector with tweezers.
    • Then take out the battery flex cable.
  8. AirPods Charging Case Battery Replacement, Test new battery: 手順 8、 3の画像 1 AirPods Charging Case Battery Replacement, Test new battery: 手順 8、 3の画像 2 AirPods Charging Case Battery Replacement, Test new battery: 手順 8、 3の画像 3
    • Take out the battery.
    • Using a multimeter is not required to successfully replace the battery.
    • Measured by the multimeter, the battery is found to have no voltage.
    • Get a new battery that has a stable voltage of 3.6v-4.0v.
  9. AirPods Charging Case Battery Replacement, Put in new battery: 手順 9、 2の画像 1 AirPods Charging Case Battery Replacement, Put in new battery: 手順 9、 2の画像 2
    • Attach the double-sided tape to the new battery.
    • Put the new battery into the charging case and connect the battery flex cable.
  10. AirPods Charging Case Battery Replacement, Test charging: 手順 10、 2の画像 1 AirPods Charging Case Battery Replacement, Test charging: 手順 10、 2の画像 2
    • Plug in the charging cable. The case should now charge normally once more.
    • Put the earbuds in. The earbuds should charge normally too.
  11. AirPods Charging Case Battery Replacement, Attach new battery: 手順 11、 2の画像 1 AirPods Charging Case Battery Replacement, Attach new battery: 手順 11、 2の画像 2
    • Peel off the double-sided tape and attach the battery to the case.
    • Install the docking tubes.
  12. AirPods Charging Case Battery Replacement, Test functionality: 手順 12、 2の画像 1 AirPods Charging Case Battery Replacement, Test functionality: 手順 12、 2の画像 2
    • Connect the AirPods to the phone. Both the charging case and AirPods can now be charged and used normally again.
ゴール
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
REWA
メンバー登録日: 11/24/20
11,684 ポイント
53のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 33
過去 7 日: 221
過去 30 日: 1,128
今までの合計 8,897
