メインコンテンツにスキップ
Air Jordan 1 Crease and Scuff Removal
必要な工具と部品
  1. Air Jordan 1 Crease and Scuff Removal, Air Jordan 1 Crease and Scuff Removal: 手順 1、 1の画像 1
    • Unlace sneakers.
  2. Air Jordan 1 Crease and Scuff Removal: 手順 2、 1の画像 1
    • Stuff toe-box with paper towels until leather is stuffed to capacity.
  3. Air Jordan 1 Crease and Scuff Removal: 手順 3、 1の画像 1
    • Dampen a small towel.
    • Place damp towel across toe-box.
  4. Air Jordan 1 Crease and Scuff Removal: 手順 4、 1の画像 1
    • Using a flat iron, iron over the damp towel to remove toe-box creases.
  5. Air Jordan 1 Crease and Scuff Removal: 手順 5、 1の画像 1
    • Keep the towl on after ironing them to reduce odd cracks.
    • For best results, keep toe-box stuffed with paper towels until you're ready to wear.
  6. Air Jordan 1 Crease and Scuff Removal: 手順 6、 1の画像 1
    • Select Angelus Leather Paint that matches the original color of your shoes.
    • Using a small paint brush, paint over scuffs and scratches with their original color in thin, even coats.
    • Allow 20 minutes in between coats for paint to fully dry.
  7. Air Jordan 1 Crease and Scuff Removal: 手順 7、 1の画像 1
    • Re-lace sneakers.
終わりに
Once you've completed these steps, your shoes will be ready for wear.
22 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Mohammad Abdellatif
メンバー登録日: 02/22/18
751 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S4-G7, Baddour Spring 2018 University of Memphis, Team S4-G7, Baddour Spring 2018人のメンバー
UM-BADDOUR-S18S4G7
2 メンバー
5のガイドは作成済み
6 件のコメント
This is the best repair guide in the world.
Mohammad Abdellatif - 返信
i love this repair guide.
Best repair guide ever!
Lucas Beauchamp - 返信
why and how because i have the all jordan but the only jordan that have a crease is the jordan 12
Azariea Ray - 返信
Would this technique work on fearless zoom irridecent ? I know when I have had just a drop of water on then it looks oily almost like there is a fine coat of some sort on them
Brad May - 返信
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 137
過去 30 日: 397
今までの合計 91,240
