メインコンテンツにスキップ
Air Conditioning Thermostat Replacement
必要な工具と部品
  1. Air Conditioning Thermostat Replacement, Turn Off the Power: 手順 1、 3の画像 1 Air Conditioning Thermostat Replacement, Turn Off the Power: 手順 1、 3の画像 2 Air Conditioning Thermostat Replacement, Turn Off the Power: 手順 1、 3の画像 3
    • Before you begin, locate the circuit breaker switchboard for the housing unit.
    • Find the air conditioning breaker that’s typically labeled inside the breaker's panel cover.
    • Turn off the electrical breaker switch that supplies the air conditioning thermostat.
  2. Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: 手順 2、 3の画像 1 Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: 手順 2、 3の画像 2 Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: 手順 2、 3の画像 3
    • Separate the thermostat casing off of the wall plate. It should come off easily using your hands, but a pair of pliers can be used if it's being stubborn.
    • Take a picture using your phone's camera of the color-coded wiring, so it will be easier to re-attach the wiring to the new thermostat.
  3. Air Conditioning Thermostat Replacement: 手順 3、 3の画像 1 Air Conditioning Thermostat Replacement: 手順 3、 3の画像 2 Air Conditioning Thermostat Replacement: 手順 3、 3の画像 3
    • Use the Flathead 3/32" 2.5 mm Screwdriver to separate the color coded wiring.
    • Use the Phillips or flathead screwdriver to separate and un-wrap each of the color coded wires. (For example: notice the yellow wire)
    • Use the Phillips or flathead screwdriver depending on the type of model, to remove the Phillips #0 Plus screw, in order to remove the base plate.
  4. Air Conditioning Thermostat Replacement: 手順 4、 3の画像 1 Air Conditioning Thermostat Replacement: 手順 4、 3の画像 2 Air Conditioning Thermostat Replacement: 手順 4、 3の画像 3
    • Remove the old base plate of the thermostat.
    • Screw in the new base plate of the Thermostat using the Phillips or flathead screwdriver to screw in the Phillips #0 Plus screw drive.
    • Using the screwdriver; reconnect the color-coded wring based on the photo taken with your camera. (For example: Notice the yellow wiring)
  5. Air Conditioning Thermostat Replacement: 手順 5、 2の画像 1 Air Conditioning Thermostat Replacement: 手順 5、 2の画像 2
    • Use your fingers to wrap the copper around the terminal slots, Use your Flathead 3/32" 2.5 mm Screwdriver to tighten the terminal slots. (For example: Notice the yellow wiring)
    • Fasten the terminal slots using your Phillips Flathead 3/32" 2.5 mm Screwdriver.
  6. Air Conditioning Thermostat Replacement: 手順 6、 2の画像 1 Air Conditioning Thermostat Replacement: 手順 6、 2の画像 2
    • Place the new thermostat casing over the base plate.
    • Snap on the thermostat casing.
  7. Air Conditioning Thermostat Replacement: 手順 7、 3の画像 1 Air Conditioning Thermostat Replacement: 手順 7、 3の画像 2 Air Conditioning Thermostat Replacement: 手順 7、 3の画像 3
    • Locate the circuit breaker switchboard for the housing unit.
    • Locate the air conditioning electrical breaker switch.
    • Turn on the electrical breaker switch that the air conditioning thermostat supplies.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Genesis
メンバー登録日: 03/01/17
163 ポイント
1ガイドが承認済み
1件のガイドコメント
ما هو السبب خروج علامت E3 في اسبلت westtin
السبلت ٣ طن عمودي
Hassan Alkanan - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 31
今までの合計 2,155
