メインコンテンツにスキップ
Air Blasters Tek Six Reload Slider Spring Replacement
必要な工具と部品
  1. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: 手順 1、 3の画像 1 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: 手順 1、 3の画像 2 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: 手順 1、 3の画像 3
    • Using a Phillips #00 screwdriver, remove the two 11.6 mm screws that hold the grey slider together
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: 手順 2、 3の画像 1 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: 手順 2、 3の画像 2 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: 手順 2、 3の画像 3
    • Using a Phillips #00 screwdriver, remove the six 9 mm screws that secure the main body.
  3. Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: 手順 3、 3の画像 1 Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: 手順 3、 3の画像 2 Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: 手順 3、 3の画像 3
    • Using the plastic opening tools, carefully separate the main case of the blaster to expose the inside.
  4. Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: 手順 4、 3の画像 1 Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: 手順 4、 3の画像 2 Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: 手順 4、 3の画像 3
    • Carefully grab the metal pin keeping the air system and top spring, and slide it outwards. This will release the air system with the plunger completely.
  5. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw holding the top spring to reload slider: 手順 5、 2の画像 1 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw holding the top spring to reload slider: 手順 5、 2の画像 2
    • Using a Phillips #00 screwdriver, remove the 7.5 mm Phillips #00 screw holding the top spring to the reload slider.
終わりに
作成者
8人の作成者と共同で作成されました。
Alfredo Antolinez
メンバー登録日: 09/22/14
347 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 3-1, Brown Fall 2014 USF Tampa, Team 3-1, Brown Fall 2014人のメンバー
USFT-BROWN-F14S3G1
3 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 512
