メインコンテンツにスキップ
Air Blasters Tek Six Plunger Replacement
必要な工具と部品
  1. Air Blasters Tek Six Plunger Replacement, Remove screws of the grey slider: 手順 1、 3の画像 1 Air Blasters Tek Six Plunger Replacement, Remove screws of the grey slider: 手順 1、 3の画像 2 Air Blasters Tek Six Plunger Replacement, Remove screws of the grey slider: 手順 1、 3の画像 3
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Plunger Replacement, Remove screws in main  body: 手順 2、 3の画像 1 Air Blasters Tek Six Plunger Replacement, Remove screws in main  body: 手順 2、 3の画像 2 Air Blasters Tek Six Plunger Replacement, Remove screws in main  body: 手順 2、 3の画像 3
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Plunger Replacement, Take the main body apart: 手順 3、 3の画像 1 Air Blasters Tek Six Plunger Replacement, Take the main body apart: 手順 3、 3の画像 2 Air Blasters Tek Six Plunger Replacement, Take the main body apart: 手順 3、 3の画像 3
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Plunger Replacement, Remove screw holding the bottom spring to the air system: 手順 4、 1の画像 1
    • Using a screwdriver, remove the 7.5 mm phillips 00 screw holding the bottom spring to the air system.
  5. Air Blasters Tek Six Plunger Replacement, Remove metal pin: 手順 5、 3の画像 1 Air Blasters Tek Six Plunger Replacement, Remove metal pin: 手順 5、 3の画像 2 Air Blasters Tek Six Plunger Replacement, Remove metal pin: 手順 5、 3の画像 3
    • Carefully grab the metal pin keeping the air system and top spring stationary, and slide it outwards. This will release the air system with the plunger completely.
  6. Air Blasters Tek Six Plunger Replacement, Remove air system screw: 手順 6、 1の画像 1
    • Using a screwdriver, remove the 5.2 mm phillips 00 screw holding the air system to the body of the blaster.
  7. Air Blasters Tek Six Plunger Replacement, Take the air system out: 手順 7、 3の画像 1 Air Blasters Tek Six Plunger Replacement, Take the air system out: 手順 7、 3の画像 2 Air Blasters Tek Six Plunger Replacement, Take the air system out: 手順 7、 3の画像 3
    • Grab the whole air system and carefully take it out of the main body of the blaster.
  8. Air Blasters Tek Six Plunger Replacement, Remove plunger: 手順 8、 3の画像 1 Air Blasters Tek Six Plunger Replacement, Remove plunger: 手順 8、 3の画像 2 Air Blasters Tek Six Plunger Replacement, Remove plunger: 手順 8、 3の画像 3
    • Now, grab the gray plunger with your hand and slide it outwards to remove it.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Alfredo Antolinez
メンバー登録日: 09/22/14
347 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 3-1, Brown Fall 2014 USF Tampa, Team 3-1, Brown Fall 2014人のメンバー
USFT-BROWN-F14S3G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 669
