メインコンテンツにスキップ
Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement
必要な工具と部品
  1. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: 手順 1、 3の画像 1 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: 手順 1、 3の画像 2 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement, Lens Assembly: 手順 1、 3の画像 3
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 手順 2、 1の画像 1
    • Unscrew the three 4mm screws from the battery side of the device. Use a Phillips screw driver.
  3. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 手順 3、 1の画像 1
    • Remove the four screws from the back side.
  4. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 手順 4、 2の画像 1 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 手順 4、 2の画像 2
    • Remove the sticky black dots.
    • Remove the hidden screw.
  5. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 手順 5、 2の画像 1 Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 手順 5、 2の画像 2
    • Remove the two screws from the top side of the device.
    • Remove the two screws from the bottom side of the device.
  6. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 手順 6、 1の画像 1
    • Remove the rear cover.
    • Be careful not to lose the spring inside.
  7. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 手順 7、 1の画像 1
    • Pull back the front cover so that you can dislodge the side cover.
  8. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 手順 8、 1の画像 1
    • Unfold the device and be careful not to tear the black and red power supply wires.
  9. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 手順 9、 1の画像 1
    • Remove the four screws from the motherboard.
  10. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 手順 10、 1の画像 1
    • Take out the motherboard while disconnecting the flip screen's cable from underneath.
  11. Aiptek Pocket DVII 1.3M LCD Lens Assembly Replacement: 手順 11、 1の画像 1
    • Replace the Lens Assembly board.
    • Be careful not to damage any of the pins. Pull the board linearly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Gyozo Aba Hivatal
メンバー登録日: 01/21/15
561 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 6-4, Brown Winter 2015 USF Tampa, Team 6-4, Brown Winter 2015人のメンバー
USFT-BROWN-W15S6G4
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 140
