メインコンテンツにスキップ
Aiptek Pocket DVII 1.3M LCD Display Screen Replacement
必要な工具と部品
  1. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: 手順 1、 3の画像 1 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: 手順 1、 3の画像 2 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement, Display Screen: 手順 1、 3の画像 3
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 手順 2、 2の画像 1 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 手順 2、 2の画像 2
    • Remove the sticky black dots.
    • Remove the three black 4mm screws from the flip screen. Use a Phillips head screw driver.
  3. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 手順 3、 1の画像 1
    • Using an opening tool, separate the cover from the screen.
    • The cover won't completely come off. This will happen in the next step.
    • Don't be afraid to use a little more force.
  4. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 手順 4、 1の画像 1
    • Using an opening tool remove the outside cover of the flip screen.
    • Move the cover towards the lens and then away from the screen.
  5. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 手順 5、 2の画像 1 Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 手順 5、 2の画像 2
    • With the cover off, push the brown locking mechanism up, so the picture cable can be remove.
    • You only need to unplug the bottom cable in the picture.
  6. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 手順 6、 1の画像 1
    • Remove the two black screws from the circuit board.
  7. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 手順 7、 1の画像 1
    • With the opening tool, pop up the screen assembly.
    • The screen is glued to the black cover. Use more force if needed.
  8. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 手順 8、 1の画像 1
    • As in step 5, push up the brown locking mechanism of the remaining cable.
    • Unplug the picture cable.
  9. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 手順 9、 1の画像 1
    • Turn the circuit board over and with a soldering gun remove the two wires on each end.
    • Use a screwdriver to pull the loosened wire away.
  10. Aiptek Pocket DVII 1.3M LCD Display Screen Replacement: 手順 10、 1の画像 1
    • With the wires no longer holding the circuit board and screen together, remove and replace the broken screen.
終わりに
作成者
3人の作成者と共同で作成されました。
Gyozo Aba Hivatal
メンバー登録日: 01/21/15
561 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 6-4, Brown Winter 2015 USF Tampa, Team 6-4, Brown Winter 2015人のメンバー
USFT-BROWN-W15S6G4
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 9
今までの合計 350
