メインコンテンツにスキップ
Aiptek DZO-V58N Speaker Replacement
必要な工具と部品
  1. Aiptek DZO-V58N Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
    • Slide the battery compartment cover down off of the camera body.
  2. Aiptek DZO-V58N Speaker Replacement: 手順 2、 1の画像 1
    • Pry up the battery from the bottom using a finger and remove the batter from the case.
  3. Aiptek DZO-V58N Speaker Replacement, Lens Protector: 手順 3、 1の画像 1
    • Remove the lanyard by pulling the grey lace through the black string loop.
    • Pull black string loop through the silver bracket.
  4. Aiptek DZO-V58N Speaker Replacement: 手順 4、 1の画像 1
    • Use a plastic opening tool to pry off the black control cover.
    • The face plates are glued, so use force to pry the face plates from the camera body.
  5. Aiptek DZO-V58N Speaker Replacement: 手順 5、 1の画像 1
    • Use a plastic opening tool to pry off the ridged back face plate and the black button.
    • The button is loose and should come off with little or no effort.
  6. Aiptek DZO-V58N Speaker Replacement: 手順 6、 1の画像 1
    • Use a plastic opening tool to pry off the silver face plate.
  7. Aiptek DZO-V58N Speaker Replacement: 手順 7、 3の画像 1 Aiptek DZO-V58N Speaker Replacement: 手順 7、 3の画像 2 Aiptek DZO-V58N Speaker Replacement: 手順 7、 3の画像 3
    • Open the USB cover to expose the small machine screw.
    • Use the Phillips #00 screwdriver to unscrew the six 0.5cm machine case screws (distributed around the camera body).
    • These small screws are easy to lose. Place the removed screws in an organized container to avoid losing them.
  8. Aiptek DZO-V58N Speaker Replacement: 手順 8、 1の画像 1
    • Pull off the side control panel.
  9. Aiptek DZO-V58N Speaker Replacement: 手順 9、 2の画像 1 Aiptek DZO-V58N Speaker Replacement: 手順 9、 2の画像 2
    • Flip open the screen by pulling the loose end of the screen away from the case.
    • Use tweezers to remove the two outside rubber dots to reveal the two 0.5cm machine screws.
    • Use the #00 Phillips Screwdriver to remove both screws.
  10. Aiptek DZO-V58N Speaker Replacement: 手順 10、 2の画像 1 Aiptek DZO-V58N Speaker Replacement: 手順 10、 2の画像 2
    • Pull the body apart from the bottom of device just enough to make space to remove the silver plastic strap holder.
    • Use tweezers to remove the silver plastic strap holder.
    • Use a plastic opening tool to pry off the lens protector.
  11. Aiptek DZO-V58N Speaker Replacement, Speaker: 手順 11、 3の画像 1 Aiptek DZO-V58N Speaker Replacement, Speaker: 手順 11、 3の画像 2 Aiptek DZO-V58N Speaker Replacement, Speaker: 手順 11、 3の画像 3
    • Unscrew the two silver 0.5cm machine screws with the #00 Phillips screwdriver.
    • Lift off the lens protector housing.
    • Pull apart the two halves of the camera body.
    • Do not pull the two halves apart too far because the wires may detach.
  12. Aiptek DZO-V58N Speaker Replacement: 手順 12、 1の画像 1
    • Use the #00 Phillips screwdriver to unscrew the two black speaker screws.
    • Lift off plastic cover.
  13. Aiptek DZO-V58N Speaker Replacement: 手順 13、 1の画像 1
    • Unplug the speaker from the circuit board by pulling out the white plastic connector.
    • Make sure to pull plastic connector and not wires because the wires could be damaged.
    • Lift out the speaker.
終わりに
作成者
3人の作成者と共同で作成されました。
Zachary Yun
メンバー登録日: 04/03/12
7 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 5-5, Forte Spring 2012 Cal Poly, Team 5-5, Forte Spring 2012人のメンバー
CPSU-FORTE-S12S5G5
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 11
今までの合計 440
