メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Afterglow Wireless PS3 Controller Button Replacement
必要な工具と部品
  1. Afterglow Wireless PS3 Controller Button Replacement, Back Cover: 手順 1、 2の画像 1 Afterglow Wireless PS3 Controller Button Replacement, Back Cover: 手順 1、 2の画像 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Button Replacement, Button: 手順 2、 2の画像 1 Afterglow Wireless PS3 Controller Button Replacement, Button: 手順 2、 2の画像 2
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
  3. Afterglow Wireless PS3 Controller Button Replacement: 手順 3、 1の画像 1
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
  4. Afterglow Wireless PS3 Controller Button Replacement: 手順 4、 2の画像 1 Afterglow Wireless PS3 Controller Button Replacement: 手順 4、 2の画像 2
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    • Set aside the mini-motherboards so you can access the main motherboard.
  5. Afterglow Wireless PS3 Controller Button Replacement: 手順 5、 2の画像 1 Afterglow Wireless PS3 Controller Button Replacement: 手順 5、 2の画像 2
    • Pull both vibration motors straight up from their holding place.
  6. Afterglow Wireless PS3 Controller Button Replacement: 手順 6、 2の画像 1 Afterglow Wireless PS3 Controller Button Replacement: 手順 6、 2の画像 2
    • Unscrew the two 9mm Phillips #0 screws holding the motherboard to the controller front plate.
  7. Afterglow Wireless PS3 Controller Button Replacement: 手順 7、 2の画像 1 Afterglow Wireless PS3 Controller Button Replacement: 手順 7、 2の画像 2
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The buttons have mini-motherboards secured in place on the front plate. Carefully pull these out.
  8. Afterglow Wireless PS3 Controller Button Replacement: 手順 8、 3の画像 1 Afterglow Wireless PS3 Controller Button Replacement: 手順 8、 3の画像 2 Afterglow Wireless PS3 Controller Button Replacement: 手順 8、 3の画像 3
    • Pick up the controller front plate and carefully turn it over so that the buttons left in it will fall out.
    • You may want to flip it while holding it over a container so the buttons do not go bouncing away from your work space.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Aj Coello
メンバー登録日: 02/17/17
1,164 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team S19-G5, Hoffman Spring 2017 USF Tampa, Team S19-G5, Hoffman Spring 2017人のメンバー
USFT-HOFFMAN-S17S19G5
4 メンバー
20のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 23
過去 30 日: 92
今までの合計 2,530
