メインコンテンツにスキップ
Afridev Axle and Handle Replacement
必要な工具と部品
  1. Afridev Axle and Handle Replacement, Head: 手順 1、 2の画像 1 Afridev Axle and Handle Replacement, Head: 手順 1、 2の画像 2
    • Assemble the required tools, including the Afridev tool and crescent wrenches.
  2. Afridev Axle and Handle Replacement: 手順 2、 3の画像 1 Afridev Axle and Handle Replacement: 手順 2、 3の画像 2 Afridev Axle and Handle Replacement: 手順 2、 3の画像 3
    • Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
  3. Afridev Axle and Handle Replacement: 手順 3、 2の画像 1 Afridev Axle and Handle Replacement: 手順 3、 2の画像 2
    • Loosen the bolt on front of the face plate with the Afridev tool.
    • Remove the plate from the pump by lifting it straight up.
  4. Afridev Axle and Handle Replacement, Axle and Handle: 手順 4、 3の画像 1 Afridev Axle and Handle Replacement, Axle and Handle: 手順 4、 3の画像 2 Afridev Axle and Handle Replacement, Axle and Handle: 手順 4、 3の画像 3
    • Insert the T-handle into the top cylinder of the exposed pump rod.
  5. Afridev Axle and Handle Replacement: 手順 5、 2の画像 1 Afridev Axle and Handle Replacement: 手順 5、 2の画像 2
    • Loosen the 2 bolts on either side of handle.
    • It is not necessary to remove the bolt at this time; however, take caution to not let the bolt fall out of the handle.
  6. Afridev Axle and Handle Replacement: 手順 6、 3の画像 1 Afridev Axle and Handle Replacement: 手順 6、 3の画像 2 Afridev Axle and Handle Replacement: 手順 6、 3の画像 3
    • Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
  7. Afridev Axle and Handle Replacement: 手順 7、 2の画像 1 Afridev Axle and Handle Replacement: 手順 7、 2の画像 2
    • Lift the handle to a horizontal position.
  8. Afridev Axle and Handle Replacement: 手順 8、 3の画像 1 Afridev Axle and Handle Replacement: 手順 8、 3の画像 2 Afridev Axle and Handle Replacement: 手順 8、 3の画像 3
    • While one person lifts up on the T-handle, remove the bolt and connection pieces.
  9. Afridev Axle and Handle Replacement: 手順 9、 3の画像 1 Afridev Axle and Handle Replacement: 手順 9、 3の画像 2 Afridev Axle and Handle Replacement: 手順 9、 3の画像 3
    • Remove the bolt and connection pieces from the handle.
    • Set the bolt pieces in a sanitary place, such as a bucket, to prevent contamination.
  10. Afridev Axle and Handle Replacement: 手順 10、 2の画像 1 Afridev Axle and Handle Replacement: 手順 10、 2の画像 2
    • Remove the handle from the pump.
    • Be sure to set the handle in a sanitary place to prevent contamination.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Jake Devincenzi
メンバー登録日: 04/18/11
118,782 ポイント
57のガイドは作成済み
2件のガイドコメント
J'ai besoin de pompe
Sylvain Monga - 返信
Sylvain Monga - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 20
今までの合計 822
