メインコンテンツにスキップ
AeraMax Pro AM III Air Filter Replacement
特集記事
  1. AeraMax Pro AM III Air Filter Replacement, Air Filter: 手順 1、 3の画像 1 AeraMax Pro AM III Air Filter Replacement, Air Filter: 手順 1、 3の画像 2 AeraMax Pro AM III Air Filter Replacement, Air Filter: 手順 1、 3の画像 3
    • If the access panel is locked, use the key to unlock it and open it by pressing the levers on both sides.
    • The appliance can open only if both levers are pressed simultaneously.
    • Use your hands to remove the old filter.
  2. AeraMax Pro AM III Air Filter Replacement: 手順 2、 3の画像 1 AeraMax Pro AM III Air Filter Replacement: 手順 2、 3の画像 2 AeraMax Pro AM III Air Filter Replacement: 手順 2、 3の画像 3
    • When removing the old filter, do not throw away the filter cage. Wipe it down and prepare to use it for the new filter.
    • If you have not already wiped down your appliance, give it a thorough wipe-down with your preferred cleaning product.
  3. AeraMax Pro AM III Air Filter Replacement: 手順 3、 3の画像 1 AeraMax Pro AM III Air Filter Replacement: 手順 3、 3の画像 2 AeraMax Pro AM III Air Filter Replacement: 手順 3、 3の画像 3
    • Remove the plastic from the new HEPA filter and place it into the filter cage.
  4. AeraMax Pro AM III Air Filter Replacement: 手順 4、 3の画像 1 AeraMax Pro AM III Air Filter Replacement: 手順 4、 3の画像 2 AeraMax Pro AM III Air Filter Replacement: 手順 4、 3の画像 3
    • Insert the carbon filter into the filter cage that you wiped down and make sure the corners are aligned with the filter cage.
    • Take your new HEPA filter and make sure the stickers are aligned and the corners of the pre-filter are fleshed down until it sticks to the carbon filter.
  5. AeraMax Pro AM III Air Filter Replacement: 手順 5、 3の画像 1 AeraMax Pro AM III Air Filter Replacement: 手順 5、 3の画像 2 AeraMax Pro AM III Air Filter Replacement: 手順 5、 3の画像 3
    • Insert your filter cage back into the access panel and make sure that the filter label is visible and facing upwards.
    • You can give your appliance one more wipe-down to ensure cleanliness.
  6. AeraMax Pro AM III Air Filter Replacement: 手順 6、 3の画像 1 AeraMax Pro AM III Air Filter Replacement: 手順 6、 3の画像 2 AeraMax Pro AM III Air Filter Replacement: 手順 6、 3の画像 3
    • Press the HEPA Setting for three seconds until the icon turns green.
    • The green icon indicates that the filter has been replaced and is ready to be used.
    • Close the access panel.
ゴール
ある他の人がこのガイドを完成しました。
添付文書
作成者
1人の作成者と共同作成されました。
Pita Vaouli
メンバー登録日: 08/22/22
157 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team P-2, Briggs Fall 2022 CSU Los Angeles, Team P-2, Briggs Fall 2022人のメンバー
CSULA-BRIGGS-F22SPG2
1 メンバー
1のガイドは作成済み
コメント 1 件
I have a brand new Air purifier just like the one in your demonstration I would like to sell, it's still in the box. I don't know how much to ask for it or where I can sell it. Can you help me?
Danette Dinot - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 16
今までの合計 184
