メインコンテンツにスキップ
Adjusting the front bonnet
必要な工具と部品
  1. Adjusting the front bonnet, Locate the closing mechanism on the bonnet: 手順 1、 1の画像 1
    • Open the bonnet from the inside of the car (use the lever in the glove-box) and raise the bonnet completely open.
    • The 13mm screw used to adjust the closing mechanism of the bonnet. This is the one that probably needs adjustment
    • Screws which secure the mechanism to the bonnet
    • Spring which raises the bonnet slightly so that it can be further opened by hand
  2. Adjusting the front bonnet, Adjust closing mechanism using the screw: 手順 2、 1の画像 1
    • Use the 13mm Wrench to screw/unscrew the bonnet closing mechanism so that it gets adjusted. Usually it needs unscrewing a little so that it reaches the closing mechanism on the car.
    • The missing black paint on the screw indicates how much this bonnet closing mechanism needed adjustment
    • After adjusting, if unscrewing was needed and the closing mechanism screw shows unpainted parts it would be wise to spray-paint the area to protect from corrosion/rust in the future.
終わりに
After adjustment the front bonnet should fully close easily when lowering.
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Dan Mihai Ile
メンバー登録日: 10/16/12
186 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 14
過去 30 日: 85
今までの合計 4,183
