メインコンテンツにスキップ
Adjusting the Rear Derailleur
必要な工具と部品
  1. Adjusting the Rear Derailleur, Bike Chain Removal: 手順 1、 2の画像 1 Adjusting the Rear Derailleur, Bike Chain Removal: 手順 1、 2の画像 2
    • Slide the chain cutting tool onto the desired link.
    • Align the push pin of the tool with the pin on the chain, and tighten the tool until the pin protrudes out the other side without falling all the way out.
  2. Adjusting the Rear Derailleur: 手順 2、 1の画像 1
    • Stop pushing the pin out when it is just held in by the outer link, so it doesn't fall all the way out. You will still be able to separate the links.
    • Repeat the previous step to take off sections of links.
  3. Adjusting the Rear Derailleur, Rear Derailleur: 手順 3、 2の画像 1 Adjusting the Rear Derailleur, Rear Derailleur: 手順 3、 2の画像 2
    • Bolt the derailleur to the mounting tab with an Allen wrench.
    • Be careful not to over-tighten the steel bolt, as this can strip the aluminum mounting tab.
  4. Adjusting the Rear Derailleur: 手順 4、 3の画像 1 Adjusting the Rear Derailleur: 手順 4、 3の画像 2 Adjusting the Rear Derailleur: 手順 4、 3の画像 3
    • Shift the rear derailleur into the highest gear(smallest sprocket).
    • Align the rear guide sprocket of the derailleur with the highest gear (smallest sprocket), by tightening or loosening the screw labeled "H".
  5. Adjusting the Rear Derailleur: 手順 5、 3の画像 1 Adjusting the Rear Derailleur: 手順 5、 3の画像 2 Adjusting the Rear Derailleur: 手順 5、 3の画像 3
    • Shift the rear derailleur into the lowest gear(largest sprocket).
    • Align the rear guide sprocket of the derailleur with the lowest gear(largest sprocket), by tightening or loosening the screw labeled "L".
  6. Adjusting the Rear Derailleur: 手順 6、 2の画像 1 Adjusting the Rear Derailleur: 手順 6、 2の画像 2
    • Shift the bike into the highest numbered gear.
    • Slide the cable through the barrel adjuster screw until the cable housing bottoms out.
    • Pull the slack out of the cable while clamping it down with the nut that is attached to the derailleur.
  7. Adjusting the Rear Derailleur: 手順 7、 3の画像 1 Adjusting the Rear Derailleur: 手順 7、 3の画像 2 Adjusting the Rear Derailleur: 手順 7、 3の画像 3
    • Route the chain around the chain rings, cassette, and derailleur.
    • Reconnect both ends of the chain using a master link or a chain cutter tool.
    • See the chain connection guide.
  8. Adjusting the Rear Derailleur: 手順 8、 1の画像 1
    • Fine tune the derailleur by tightening or loosening the barrel adjuster screw. Loosening this screw causes the derailleur to move slightly towards a larger sprocket, while tightening it moves the derailler towards a smaller sprocket.
    • Shift through each gear while pedaling. The derailleur should move the chain one gear over each time you shift up or down.
    • If the chain skips or makes noise when you are not shifting, use the barrel adjustment screw to fine tune the derailleur alignment.
    • Repeat the previous steps until the derailleur shifts smoothly and makes a minimal amount of noise.
    when shifting down to a higher gear, there is a distinctive delay before the chain drops to the next gear???
    Ned Wanoa - 返信
終わりに
For future adjustments it is likely that you will only need to adjust the barrel adjuster screw for fine adjustment.
8 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Travis Tonder
メンバー登録日: 10/05/10
3,210 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S5G13
4 メンバー
17のガイドは作成済み
3 件のコメント
Thanks Travis! I was a little unsure about how to do this without ruining my derailleur! Thx alot!
Tim - 返信
Thanks the direction is simple enough.
Robert - 返信
I always wondered how to align the guide wheel and the sprockets. Now I have a better idea.
Edwin Icogo - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 26
過去 30 日: 80
今までの合計 22,348
