メインコンテンツにスキップ
Adjust Goose-neck (adjustable quill stem) on Specialized Expedition
必要な工具と部品
  1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 手順 1、 2の画像 1 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 手順 1、 2の画像 2
    • Remove the bolt cover with a flathead screwdriver.
  2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 手順 2、 3の画像 1 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 手順 2、 3の画像 2 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 手順 2、 3の画像 3
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  3. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 手順 3、 3の画像 1 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 手順 3、 3の画像 2 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: 手順 3、 3の画像 3
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
ゴール
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
aaron thielk
メンバー登録日: 10/10/10
1,882 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S5G13
4 メンバー
17のガイドは作成済み
コメント 1 件
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 9,282
