はじめに
This guide will show you how to adjust the height of the handle bars and align the stem with the front wheel.
パーツ
パーツは必要ありません。
  1. Remove the bolt cover with a flathead screwdriver. Remove the bolt cover with a flathead screwdriver.
    • Remove the bolt cover with a flathead screwdriver.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench. After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side. If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  4. Align the direction of the goose-neck (adjustable quill stem) with the front tire. Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench. Pop the bolt cover back on.
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
ゴール
ある他の人がこのガイドを完成しました。
aaron thielk
メンバー登録日: 2010年10月10日
1,726 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S5G13
4 メンバー
11のガイドは作成済み
コメント1件
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - 返信
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 7,874
