この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This is a step by step replacement guide for the bridge of an acoustic guitar. Replacing the bridge on a guitar may be necessary if the bridge is damaged or falling off. This is a fairly simple task and can be accomplished very easily by following this simple 10 step guide. No prior guitar repair experience or special tools are needed to accomplish this task. Just be careful, follow the steps, and it should turn out great!
必要な工具と部品
Remove the guitar strings.
Use a paper towel to remove any dust and debris from the neck of the guitar.
ある他の人がこのガイドを完成しました。
コメント 1 件
This is a good guide Mitchell. I would encourage anyone attempting this type of a job to go watch some of the videos on YouTube by Mr. Ted Woodford. He goes into great detail about the various pitfalls of removing bridges, they aren't always as simple. Personally I don't think this repair is something to be classified as 'easy' as well. Different guitars can have very very tough adhesive bonds. I had to remove a Taylor bridge once that was a bear to get off and ensure that it went back on cleanly. The bridge can also warp and deform once it comes free of the top, so it's a good idea to clamp the bridge to a known flat surface. I appreciate the steps you outlined here though.
Ryan Field - 返信
