はじめに
Overtime, battery life on many laptops, including the Acer TravelMate P653-V-6882, come to an end. This is due to old age, constant use while plugged in, or not recharging/discharging it to its extremes.
If your TravelMate’s battery has come to an end, here is a guide on how to remove the TravelMate’s battery pack!
Before you begin replacing the battery pack, it is important that you power off your TravelMate and ensure that it is not plugged in.
Turn the computer over so the base is facing up.
Slide the battery lock to unlock position.
ある他の人がこのガイドを完成しました。
