メインコンテンツにスキップ
Acer Spin 7 SP714-51 Trackpad Replacement
必要な工具と部品
  1. Acer Spin 7 SP714-51 Trackpad Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop so that the back cover is visible and facing you. Make sure it is on a flat surface such as a table.
    • Use a Phillips #0 screwdriver to remove the 6 mm screws along the edge of the bottom cover.
  2. Acer Spin 7 SP714-51 Trackpad Replacement: 手順 2、 1の画像 1
    • Once all the screws are removed, you should easily be able to remove the back cover. This can be done by hand or by using a Spudger as seen in the tools list.
  3. Acer Spin 7 SP714-51 Trackpad Replacement: 手順 3、 2の画像 1 Acer Spin 7 SP714-51 Trackpad Replacement: 手順 3、 2の画像 2
    • Remove the battery connector cable from the motherboard.
    • This will cut power to the laptop, reducing the likelihood of damage and injury.
    • Ensure that you are pulling the connector straight back, if you pull up at all you may damage the battery connector on the motherboard.
  4. Acer Spin 7 SP714-51 Trackpad Replacement: 手順 4、 2の画像 1 Acer Spin 7 SP714-51 Trackpad Replacement: 手順 4、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the last two 3mm long fasteners at the edge of the laptop body, and carefully remove the battery.
    • Place the new battery in the battery slot
    • Do not bend or puncture the battery.
  5. Acer Spin 7 SP714-51 Trackpad Replacement, Trackpad: 手順 5、 1の画像 1
    • Use your fingernail or another small pry tool to gently pry up the black locking tab on the ribbon cable connector, then slide the ribbon cable out gently holding the blue tab attached to the cable.
    • Take great care not to damage the ribbon cable or the cable connector.
  6. Acer Spin 7 SP714-51 Trackpad Replacement: 手順 6、 2の画像 1 Acer Spin 7 SP714-51 Trackpad Replacement: 手順 6、 2の画像 2
    • Use a Phillips #000 screwdriver to remove the five 2mm screws from the back of the trackpad, then carefully remove the trackpad and set it aside.
終わりに
作成者
4人の作成者と共同で作成されました。
Zach Desrosiers
メンバー登録日: 03/22/22
565 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 UMass Dartmouth, Team 7-3, Sinclaire Spring 2022人のメンバー
UMASSD-SINCLAIRE-S22S7G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 155
