メインコンテンツにスキップ
Acer Spin 7 SP714-51 Battery Replacement
必要な工具と部品
  1. Acer Spin 7 SP714-51 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop so that the back cover is visible and facing you. Make sure it is on a flat surface such as a table.
    • Use a Phillips #0 screwdriver to remove the 6 mm screws along the edge of the bottom cover.
  2. Acer Spin 7 SP714-51 Battery Replacement: 手順 2、 1の画像 1
    • Once all the screws are removed, you should easily be able to remove the back cover. This can be done by hand or by using a Spudger as seen in the tools list.
  3. Acer Spin 7 SP714-51 Battery Replacement: 手順 3、 2の画像 1 Acer Spin 7 SP714-51 Battery Replacement: 手順 3、 2の画像 2
    • Remove the battery connector cable from the motherboard.
    • This will cut power to the laptop, reducing the likelihood of damage and injury.
    • Ensure that you are pulling the connector straight back, if you pull up at all you may damage the battery connector on the motherboard.
  4. Acer Spin 7 SP714-51 Battery Replacement: 手順 4、 2の画像 1 Acer Spin 7 SP714-51 Battery Replacement: 手順 4、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the last two 3mm long fasteners at the edge of the laptop body, and carefully remove the battery.
    • Place the new battery in the battery slot
    • Do not bend or puncture the battery.
終わりに
作成者
4人の作成者と共同で作成されました。
Zach Desrosiers
メンバー登録日: 03/22/22
565 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 7-3, Sinclaire Spring 2022 UMass Dartmouth, Team 7-3, Sinclaire Spring 2022人のメンバー
UMASSD-SINCLAIRE-S22S7G3
4 メンバー
5のガイドは作成済み
2 件のコメント
The connector can be plugged in two different ways: RED wires to the left or to the right. Which is correct?
William Barrett - 返信
As pictured, I believe it is red wires to the left when orienting the laptop with the battery slot closest to you. However, this was for a technical communications project I and others wrote some time ago for college, and as such I no longer have access to the laptop so I cannot confirm for sure. Let me know if you have any other questions, I’d be happy to help out if I can.
- Zach D
Zach Desrosiers -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 44
今までの合計 980
