はじめに
The cooling fan in responsible for keeping the computer at a healthy temperature. If you notice that your laptop is warmer than usual and randomly shuts itself off without warning you may need to replace your fan to renew the cooling capabilities of your laptop. This guide will show you how to replace the cooling fan in the Acer Spin 5 SP513-51-57TP laptop.
必要な工具と部品
Flip your laptop over so that the model sticker is facing upward towards the ceiling.
Use Phillips #1 screwdriver to remove the two 4mm screws that are securing the fan.
ある他の人がこのガイドを完成しました。
