はじめに
The main component of the Acer Spin 3 SP315-51-757C is the motherboard, since it is the central piece of the computer than connects all other parts. A faulty motherboard can be the cause of a large number of problems. Replacing your motherboard should only be your last resort if no other guides fix your computer’s issue.
必要な工具と部品
Using your nails or tweezers, unplug the charger port cable from the motherboard.
Lift the three black tabs to release the cable connectors.
After the tabs are lifted, the white cables with blue ends can be pulled out of their slots.
4 の人々がこのガイドを完成させました。
