メインコンテンツにスキップ
Acer S200HL LCD Monitor Motherboard Replacement
必要な工具と部品
  1. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Stand: 手順 1、 2の画像 1 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Stand: 手順 1、 2の画像 2
    • Place the monitor screen face down.
    • Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
    • Pull the stand away from the monitor.
  2. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: 手順 2、 3の画像 1 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: 手順 2、 3の画像 2 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: 手順 2、 3の画像 3
    • Use the plastic opening tool to pry the back panel from the front panel.
    • Start at one point of the crease and pry along the edge of the entire monitor for the best results.
  3. Acer S200HL LCD Monitor Motherboard Replacement: 手順 3、 1の画像 1
    • Gently lift back panel away from the monitor.
  4. Acer S200HL LCD Monitor Motherboard Replacement, Removing Interior Motherboard Casing: 手順 4、 2の画像 1 Acer S200HL LCD Monitor Motherboard Replacement, Removing Interior Motherboard Casing: 手順 4、 2の画像 2
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    • Be sure to keep track of where you place your screws. A magnetic mat is great for keeping your screws in one spot.
    • Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
  5. Acer S200HL LCD Monitor Motherboard Replacement: 手順 5、 2の画像 1 Acer S200HL LCD Monitor Motherboard Replacement: 手順 5、 2の画像 2
    • Remove the four 10 mm hex screws.
  6. Acer S200HL LCD Monitor Motherboard Replacement: 手順 6、 1の画像 1
    • Gently lift the motherboard casing from the monitor.
  7. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Connections to the Motherboard: 手順 7、 1の画像 1
    • The following steps circled in yellow are the locations for detaching the three connectors shown in the picture.
  8. Acer S200HL LCD Monitor Motherboard Replacement, Removing the No Fuss Ribbon Cable Connector: 手順 8、 1の画像 1
    • Lift the black seal to release the small ribbon connector (the No Fuss Ribbon Cable connector) from the motherboard.
    • The connector will be released from the motherboard immediately.
  9. Acer S200HL LCD Monitor Motherboard Replacement, Removing the ZIF Connectors: 手順 9、 1の画像 1
    • Lift the black seal to release the large ribbon connector (the ZIF connector).
  10. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Bundled Cable Connector: 手順 10、 1の画像 1
    • Pull the bundled cable connector gently away from motherboard.
  11. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Motherboard: 手順 11、 1の画像 1
    • Gently lift the motherboard to remove it from the monitor.
終わりに
8 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Jeffrey Kong
メンバー登録日: 09/22/14
885 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 12-3, Forte Fall 2014 Cal Poly, Team 12-3, Forte Fall 2014人のメンバー
CPSU-FORTE-F14S12G3
5 メンバー
10のガイドは作成済み
2件のガイドコメント
como saber si es la board o las lamparas q trae la pantalla?
y cual es la forma de reparar las lamparas
Doc acvdo - 返信
What is the specific name of that dc-in power jack?I’ m trying to replace that thing with a new one,the current one is already faulty.Can u recommend me where to find that part?Thanks!
Oreo - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 39
今までの合計 7,999
