メインコンテンツにスキップ
Acer S200HL LCD Monitor Bundled Cable Connector Replacement
必要な工具と部品
  1. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Stand: 手順 1、 2の画像 1 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Stand: 手順 1、 2の画像 2
    • Place the monitor screen face down.
    • Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
    • Pull the stand away from the monitor.
  2. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: 手順 2、 3の画像 1 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: 手順 2、 3の画像 2 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Back Panel: 手順 2、 3の画像 3
    • Use the plastic opening tool to pry the back panel from the front panel.
    • Start at one point of the crease and pry along the entire monitor for the best results.
  3. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 手順 3、 1の画像 1
    • Gently lift the back panel away from the monitor.
  4. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing Interior Motherboard Casing: 手順 4、 2の画像 1 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing Interior Motherboard Casing: 手順 4、 2の画像 2
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • Be sure to keep track of where you place your screws. A magnetic mat is great for keeping your screws in one spot.
    • Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
  5. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 手順 5、 2の画像 1 Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 手順 5、 2の画像 2
    • Remove the four 10 mm hex screws.
  6. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 手順 6、 1の画像 1
    • Gently lift the motherboard casing from the monitor.
  7. Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Bundled Cable Connections: 手順 7、 2の画像 1 Acer S200HL LCD Monitor Bundled Cable Connector Replacement, Removing the Bundled Cable Connections: 手順 7、 2の画像 2
    • Pull the bundled cable connector gently away from motherboard.
  8. Acer S200HL LCD Monitor Bundled Cable Connector Replacement: 手順 8、 1の画像 1
    • Grasp the other side of the bundled cable connector and gently pull the connector away from the screen.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jeffrey Kong
メンバー登録日: 09/22/14
809 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 12-3, Forte Fall 2014 Cal Poly, Team 12-3, Forte Fall 2014人のメンバー
CPSU-FORTE-F14S12G3
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 20
今までの合計 2,767
