メインコンテンツにスキップ
Acer Predator 17 G9-791 Display Replacement
必要な工具と部品
  1. Acer Predator 17 G9-791 Display Replacement, Service Panel: 手順 1、 1の画像 1
    • The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
  2. Acer Predator 17 G9-791 Display Replacement: 手順 2、 2の画像 1 Acer Predator 17 G9-791 Display Replacement: 手順 2、 2の画像 2
    • Loosen the two Phillips #0 screws.
    • Pull up slightly on the top of the panel to help fully separate the screws from the rest of the device.
  3. Acer Predator 17 G9-791 Display Replacement: 手順 3、 1の画像 1
    • Continue pulling up on the panel to separate it from the laptop and remove it.
  4. Acer Predator 17 G9-791 Display Replacement, Bottom Case: 手順 4、 3の画像 1 Acer Predator 17 G9-791 Display Replacement, Bottom Case: 手順 4、 3の画像 2 Acer Predator 17 G9-791 Display Replacement, Bottom Case: 手順 4、 3の画像 3
    • Remove the nine 4.5 mm Phillips #0 screws from the panel.
    • Remove four 14 mm Phillips #0 screws.
    • Remove six 7 mm Phillips #0 screws.
  5. Acer Predator 17 G9-791 Display Replacement: 手順 5、 1の画像 1
    • Slide the "unlock" slider up located to the right of the service panel and pull the disc tray out.
  6. Acer Predator 17 G9-791 Display Replacement: 手順 6、 1の画像 1
    • Remove the two 4.5 mm Phillips #0 screws located underneath the removed optical drive.
  7. Acer Predator 17 G9-791 Display Replacement: 手順 7、 2の画像 1 Acer Predator 17 G9-791 Display Replacement: 手順 7、 2の画像 2
    • Pry up on the edges of the bottom cover and lift the bottom case off of the device.
  8. Acer Predator 17 G9-791 Display Replacement, Battery: 手順 8、 1の画像 1
    • Remove the six 4 mm Phillips #0 screws from the battery.
  9. Acer Predator 17 G9-791 Display Replacement: 手順 9、 2の画像 1 Acer Predator 17 G9-791 Display Replacement: 手順 9、 2の画像 2
    • Disconnect the battery connector from the motherboard.
  10. Acer Predator 17 G9-791 Display Replacement: 手順 10、 1の画像 1
    • Gently lift the battery and remove it from the device.
  11. Acer Predator 17 G9-791 Display Replacement, Fan Assembly: 手順 11、 2の画像 1 Acer Predator 17 G9-791 Display Replacement, Fan Assembly: 手順 11、 2の画像 2
    • Remove the five 4.5 mm Phillips #0 screws located on the perimeter of the fans.
  12. Acer Predator 17 G9-791 Display Replacement: 手順 12、 2の画像 1 Acer Predator 17 G9-791 Display Replacement: 手順 12、 2の画像 2
    • Unscrew the six Phillips #0 screws enough to loosen the assembly from the motherboard.
  13. Acer Predator 17 G9-791 Display Replacement: 手順 13、 3の画像 1 Acer Predator 17 G9-791 Display Replacement: 手順 13、 3の画像 2 Acer Predator 17 G9-791 Display Replacement: 手順 13、 3の画像 3
    • Detach the left fan's cord from the motherboard.
  14. Acer Predator 17 G9-791 Display Replacement: 手順 14、 3の画像 1 Acer Predator 17 G9-791 Display Replacement: 手順 14、 3の画像 2 Acer Predator 17 G9-791 Display Replacement: 手順 14、 3の画像 3
    • Detach the right fan's cord from the motherboard.
  15. Acer Predator 17 G9-791 Display Replacement: 手順 15、 3の画像 1 Acer Predator 17 G9-791 Display Replacement: 手順 15、 3の画像 2 Acer Predator 17 G9-791 Display Replacement: 手順 15、 3の画像 3
    • Lift the fan assembly up and out.
  16. Acer Predator 17 G9-791 Display Replacement, Display: 手順 16、 3の画像 1 Acer Predator 17 G9-791 Display Replacement, Display: 手順 16、 3の画像 2 Acer Predator 17 G9-791 Display Replacement, Display: 手順 16、 3の画像 3
    • Push down on the back of the device to unclip this panel, removing it by pulling it out the back of the device.
  17. Acer Predator 17 G9-791 Display Replacement: 手順 17、 2の画像 1 Acer Predator 17 G9-791 Display Replacement: 手順 17、 2の画像 2
    • Remove two black 7 mm Phillips #0 screws from the left display bracket.
    • Remove the two silver 5 mm Phillips #0 screws from the left display bracket.
  18. Acer Predator 17 G9-791 Display Replacement: 手順 18、 2の画像 1 Acer Predator 17 G9-791 Display Replacement: 手順 18、 2の画像 2
    • Remove three silver 5 mm Phillips #0 screws from the right display bracket.
    • Remove one black 7 mm Phillips #0 screw from the right display bracket.
  19. Acer Predator 17 G9-791 Display Replacement: 手順 19、 3の画像 1 Acer Predator 17 G9-791 Display Replacement: 手順 19、 3の画像 2 Acer Predator 17 G9-791 Display Replacement: 手順 19、 3の画像 3
    • Remove one 4.5 mm Phillips #0 screw from the WLAN card.
    • Pull the WLAN card out.
  20. Acer Predator 17 G9-791 Display Replacement: 手順 20、 2の画像 1 Acer Predator 17 G9-791 Display Replacement: 手順 20、 2の画像 2
    • Turn the device around.
    • Pull the black tab to disconnect one wire from the bottom of the motherboard.
  21. Acer Predator 17 G9-791 Display Replacement: 手順 21、 2の画像 1 Acer Predator 17 G9-791 Display Replacement: 手順 21、 2の画像 2
    • Opening the cover slightly, pull the bottom half of the device towards you.
  22. Acer Predator 17 G9-791 Display Replacement: 手順 22、 2の画像 1 Acer Predator 17 G9-791 Display Replacement: 手順 22、 2の画像 2
    • Separate the wire that was unplugged two steps ago from the bottom of the device.
    • This wire runs in a track and pulling on it slightly will separate it from the bottom half of the device.
    • When reinstalling, ensure this wire in placed back in its track before attempting to put the new display on the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Adeline Slocum
メンバー登録日: 10/25/22
304 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 UMass Dartmouth, Team 5-1, Sinclaire Fall 2022人のメンバー
UMASSD-SINCLAIRE-F22S5G1
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 357
