メインコンテンツにスキップ
Acer One 10 S1002 145-A Motherboard Replacement
必要な工具と部品
  1. Acer One 10 S1002 145-A Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • Make sure that the tablet is turned off and disconnected from any power source.
    • Disconnect the tablet from the keyboard attachment.
    • If you have a Micro SD card in the tablet, remove it now.
    • Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
  2. Acer One 10 S1002 145-A Motherboard Replacement: 手順 2、 2の画像 1 Acer One 10 S1002 145-A Motherboard Replacement: 手順 2、 2の画像 2
    • Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
    • Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
    • Separate the back covering from the screen.
  3. Acer One 10 S1002 145-A Motherboard Replacement: 手順 3、 3の画像 1 Acer One 10 S1002 145-A Motherboard Replacement: 手順 3、 3の画像 2 Acer One 10 S1002 145-A Motherboard Replacement: 手順 3、 3の画像 3
    • Peel off all of the Polyimide tape (yellow tape).
    • Remove the metallic tape covering the keyboard connection.
  4. Acer One 10 S1002 145-A Motherboard Replacement: 手順 4、 2の画像 1 Acer One 10 S1002 145-A Motherboard Replacement: 手順 4、 2の画像 2
    • Unscrew the two 3.5mm Phillips #0 screws and open the ZIF latch.
    • Gently remove the silver part covering the battery and set it aside.
  5. Acer One 10 S1002 145-A Motherboard Replacement: 手順 5、 3の画像 1 Acer One 10 S1002 145-A Motherboard Replacement: 手順 5、 3の画像 2 Acer One 10 S1002 145-A Motherboard Replacement: 手順 5、 3の画像 3
  6. Acer One 10 S1002 145-A Motherboard Replacement: 手順 6、 2の画像 1 Acer One 10 S1002 145-A Motherboard Replacement: 手順 6、 2の画像 2
    • Remove the four 4mm screws at the corners of the motherboard with the Phillips#0 bit screw.
    • The screw beneath the metallic tape also needs to be removed.
  7. Acer One 10 S1002 145-A Motherboard Replacement: 手順 7、 3の画像 1 Acer One 10 S1002 145-A Motherboard Replacement: 手順 7、 3の画像 2 Acer One 10 S1002 145-A Motherboard Replacement: 手順 7、 3の画像 3
    • Disconnect the three cables on the motherboard closest to the battery.
    • These cables require some extra prying power to be removed.
  8. Acer One 10 S1002 145-A Motherboard Replacement: 手順 8、 1の画像 1
    • Slide out the motherboard and put it aside.
終わりに
12 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Shannon Griffin
メンバー登録日: 10/03/16
1,372 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-3, Sullivan Fall 2016 USF Tampa, Team 1-3, Sullivan Fall 2016人のメンバー
USFT-SULLIVAN-F16S1G3
4 メンバー
5のガイドは作成済み
11 件のコメント
WOW. Thank you so much for this guide. My keyboard wasn't connecting and last time I had to send it to Acer ...and that took a month. This time it is out of warranty and it wouldn't connect again!!!.... After opening it following this guide, it was immediately visible that the cable was out.
Thank you SO much!
Alen Mijic - 返信
put it aside and then?
Double Bone - 返信
Hey,
Whenever you see a 'put aside' anywhere in a guide there's an implied 'then continue' afterwards.
Hope that helps!
Allen Tools -
Great help. Was able to restore connection for my grandson’s computer using your clear concise directions. THANK YOU!!!
Linda Byars - 返信
how can i fix my acer one s1002 keyboard dock it is not working if i connect it to the tablet i
Wencel Angelo Maturan - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 42
今までの合計 17,908
