メインコンテンツにスキップ
Acer One 10 S1002 145-A Camera Replacement
必要な工具と部品
  1. Acer One 10 S1002 145-A Camera Replacement, Motherboard: 手順 1、 1の画像 1
    • Make sure that the tablet is turned off and disconnected from any power source.
    • Disconnect the tablet from the keyboard attachment.
    • If you have a Micro SD card in the tablet, remove it now.
    • Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
  2. Acer One 10 S1002 145-A Camera Replacement: 手順 2、 2の画像 1 Acer One 10 S1002 145-A Camera Replacement: 手順 2、 2の画像 2
    • Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
    • Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
    • Separate the back covering from the screen.
  3. Acer One 10 S1002 145-A Camera Replacement: 手順 3、 3の画像 1 Acer One 10 S1002 145-A Camera Replacement: 手順 3、 3の画像 2 Acer One 10 S1002 145-A Camera Replacement: 手順 3、 3の画像 3
    • Peel off all of the Polyimide tape (yellow tape).
    • Remove the metallic tape covering the keyboard connection.
  4. Acer One 10 S1002 145-A Camera Replacement: 手順 4、 2の画像 1 Acer One 10 S1002 145-A Camera Replacement: 手順 4、 2の画像 2
    • Unscrew the two 3.5mm Phillips #0 screws and open the ZIF latch.
    • Gently remove the silver part covering the battery and set it aside.
  5. Acer One 10 S1002 145-A Camera Replacement: 手順 5、 3の画像 1 Acer One 10 S1002 145-A Camera Replacement: 手順 5、 3の画像 2 Acer One 10 S1002 145-A Camera Replacement: 手順 5、 3の画像 3
  6. Acer One 10 S1002 145-A Camera Replacement: 手順 6、 2の画像 1 Acer One 10 S1002 145-A Camera Replacement: 手順 6、 2の画像 2
    • Remove the four 4mm screws at the corners of the motherboard with the Phillips#0 bit screw.
    • The screw beneath the metallic tape also needs to be removed.
  7. Acer One 10 S1002 145-A Camera Replacement: 手順 7、 3の画像 1 Acer One 10 S1002 145-A Camera Replacement: 手順 7、 3の画像 2 Acer One 10 S1002 145-A Camera Replacement: 手順 7、 3の画像 3
    • Disconnect the three cables on the motherboard closest to the battery.
    • These cables require some extra prying power to be removed.
  8. Acer One 10 S1002 145-A Camera Replacement: 手順 8、 1の画像 1
    • Slide out the motherboard and put it aside.
  9. Acer One 10 S1002 145-A Camera Replacement, Battery: 手順 9、 3の画像 1 Acer One 10 S1002 145-A Camera Replacement, Battery: 手順 9、 3の画像 2 Acer One 10 S1002 145-A Camera Replacement, Battery: 手順 9、 3の画像 3
    • Use the plastic opening tool to separate the glue that holds the battery to the screen.
    • Avoid putting pressure on the glass while separating the battery from the screen.
    • Remove the battery and set it aside.
  10. Acer One 10 S1002 145-A Camera Replacement, Camera: 手順 10、 3の画像 1 Acer One 10 S1002 145-A Camera Replacement, Camera: 手順 10、 3の画像 2 Acer One 10 S1002 145-A Camera Replacement, Camera: 手順 10、 3の画像 3
    • Separate the adhesive cable from the underlying copper ribbon cable.
    • Gently pry off the camera from from tablet backing.
    • Remove the camera and set it aside.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Shannon Griffin
メンバー登録日: 10/03/16
1,372 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-3, Sullivan Fall 2016 USF Tampa, Team 1-3, Sullivan Fall 2016人のメンバー
USFT-SULLIVAN-F16S1G3
4 メンバー
5のガイドは作成済み
3 件のコメント
I was worried camera was broken but discovered after black screen and not working touch screen and mouse, it was not the case:
Got Acer 10 Tablet with Keyboard S1002 12V2 repaired:
1) by removing tablet from keyboard
2)pressing the volume down into volume position and pressing power at same time 30 secs
3)reset menu comes on and screen loads as normal
4) restart device
(when there is a problem with this two in one tablet, the device thinks it's a tablet before a pc)
5) admin prompts given after a restart is done which took about 40 mins; restart and flourish
***after restarting the whole pc began to work including front and rear cameras which was the issue I had contacted acer support about in the first place!)
jenny -
I am facing a big problem right now….!!
There are no screws in my tab
I can’t find those screws as shown in the picture……its just plane with all those holes nearby….
Please help me….I’m facing heavy issues……!!
Abhai - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 1,199
