メインコンテンツにスキップ
Acer One 10 S1002 145-A Battery Replacement
必要な工具と部品
  1. Acer One 10 S1002 145-A Battery Replacement, Motherboard: 手順 1、 1の画像 1
    • Make sure that the tablet is turned off and disconnected from any power source.
    • Disconnect the tablet from the keyboard attachment.
    • If you have a Micro SD card in the tablet, remove it now.
    • Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
  2. Acer One 10 S1002 145-A Battery Replacement: 手順 2、 2の画像 1 Acer One 10 S1002 145-A Battery Replacement: 手順 2、 2の画像 2
    • Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
    • Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
    • Separate the back covering from the screen.
  3. Acer One 10 S1002 145-A Battery Replacement: 手順 3、 3の画像 1 Acer One 10 S1002 145-A Battery Replacement: 手順 3、 3の画像 2 Acer One 10 S1002 145-A Battery Replacement: 手順 3、 3の画像 3
    • Peel off all of the Polyimide tape (yellow tape).
    • Remove the metallic tape covering the keyboard connection.
  4. Acer One 10 S1002 145-A Battery Replacement: 手順 4、 2の画像 1 Acer One 10 S1002 145-A Battery Replacement: 手順 4、 2の画像 2
    • Unscrew the two 3.5mm Phillips #0 screws and open the ZIF latch.
    • Gently remove the silver part covering the battery and set it aside.
  5. Acer One 10 S1002 145-A Battery Replacement: 手順 5、 3の画像 1 Acer One 10 S1002 145-A Battery Replacement: 手順 5、 3の画像 2 Acer One 10 S1002 145-A Battery Replacement: 手順 5、 3の画像 3
  6. Acer One 10 S1002 145-A Battery Replacement: 手順 6、 2の画像 1 Acer One 10 S1002 145-A Battery Replacement: 手順 6、 2の画像 2
    • Remove the four 4mm screws at the corners of the motherboard with the Phillips#0 bit screw.
    • The screw beneath the metallic tape also needs to be removed.
  7. Acer One 10 S1002 145-A Battery Replacement: 手順 7、 3の画像 1 Acer One 10 S1002 145-A Battery Replacement: 手順 7、 3の画像 2 Acer One 10 S1002 145-A Battery Replacement: 手順 7、 3の画像 3
    • Disconnect the three cables on the motherboard closest to the battery.
    • These cables require some extra prying power to be removed.
  8. Acer One 10 S1002 145-A Battery Replacement: 手順 8、 1の画像 1
    • Slide out the motherboard and put it aside.
  9. Acer One 10 S1002 145-A Battery Replacement, Battery: 手順 9、 3の画像 1 Acer One 10 S1002 145-A Battery Replacement, Battery: 手順 9、 3の画像 2 Acer One 10 S1002 145-A Battery Replacement, Battery: 手順 9、 3の画像 3
    • Use the plastic opening tool to separate the glue that holds the battery to the screen.
    • Avoid putting pressure on the glass while separating the battery from the screen.
    • Remove the battery and set it aside.
終わりに
20 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Shannon Griffin
メンバー登録日: 10/03/16
1,372 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-3, Sullivan Fall 2016 USF Tampa, Team 1-3, Sullivan Fall 2016人のメンバー
USFT-SULLIVAN-F16S1G3
4 メンバー
5のガイドは作成済み
2 件のコメント
Thankyou for this information. I am replacing a battery on my own, and your tutorial is extremely clear and helpful.
shop_arod - 返信
I want a ..
Motherboard
4D Guru Channel - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 65
今までの合計 18,676
