Make sure that the tablet is turned off and disconnected from any power source.
Disconnect the tablet from the keyboard attachment.
If you have a Micro SD card in the tablet, remove it now.
Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
Use the plastic opening tool to separate the glue that holds the battery to the screen.
Remove the battery and set it aside.
20 の人々がこのガイドを完成させました。
2 件のコメント
I want a ..
Motherboard
