はじめに
The right and left speakers on the W510 are combined into a single plug and thus cannot be replaced separately so both speakers are replaced at the same time.
必要な工具と部品
Carefully insert your metal pry tool between the back cover and the frame at an angle as shown.
Give the tool a twist to the left to start separating the clips.
Work your way to the corner, prying and twisting to pop the clips as you go.
Insert an opening pick to make sure the clips don't close down again as you round the corner and start working on the right side of the tablet.
Continue as before, prying and twisting to release the catches.
Back to the bottom side again, this little part by itself is a little finicky to get unclipped, just follow the same procedure as with the first one.
And finally the home stretch between the keyboard/power connector and the right hand guide pin, back to where you started.
Unplug the speakers.
Grasp the connector itself; do not pull on the wires to unplug the speakers.
The speaker is lightly adhered to the case with double sided tape. Use a spudger to pry the speaker up to remove it.
Starting at the left speaker, lift the wire out of the channel it sits in.
