メインコンテンツにスキップ
Acer Iconia W3-810 Screen Replacement
必要な工具と部品
  1. Acer Iconia W3-810  Screen Replacement, Back Panel: 手順 1、 1の画像 1
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810  Screen Replacement: 手順 2、 1の画像 1
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810  Screen Replacement, Battery: 手順 3、 1の画像 1
    • Pull the ribbon cord by pushing the clamp on the port toward you with the plastic opening tool.
  4. Acer Iconia W3-810  Screen Replacement: 手順 4、 1の画像 1
    • Move the ribbon cord in order to disconnect the rainbow cord from the battery.
    • Take extra care to not rip the ribbon cord.
  5. Acer Iconia W3-810  Screen Replacement: 手順 5、 1の画像 1
    • Use the plastic opening tool to carefully slide the power cord from its slot by pushing it out from both sides, then remove the cord from its port with your hand.
  6. Acer Iconia W3-810  Screen Replacement: 手順 6、 1の画像 1
    • Pull on the ribbon cord carefully in order to break the seal between the ribbon cord and the battery. Do this until the cord is completely free of the battery.
    • Do not pull the ribbon cord too hard or near the opposite end.
  7. Acer Iconia W3-810  Screen Replacement: 手順 7、 1の画像 1
    • Use the plastic opening tool to gently wedge out and lift the battery pack from the device.
  8. Acer Iconia W3-810  Screen Replacement: 手順 8、 2の画像 1 Acer Iconia W3-810  Screen Replacement: 手順 8、 2の画像 2
    • Carefully break the bond between the inner tape and the battery using the plastic opening tool. The tape can be found in the middle and either side of the battery.
  9. Acer Iconia W3-810  Screen Replacement: 手順 9、 1の画像 1
    • Remove battery pack
  10. Acer Iconia W3-810  Screen Replacement, Screen: 手順 10、 1の画像 1
    • Disconnect the speaker cord from the motherboard by carefully prying it out with a plastic opening tool.
  11. Acer Iconia W3-810  Screen Replacement: 手順 11、 1の画像 1
    • Loosen the retaining flap using a plastic opening tool, and then pull the ribbon cord from its slot.
  12. Acer Iconia W3-810  Screen Replacement: 手順 12、 2の画像 1 Acer Iconia W3-810  Screen Replacement: 手順 12、 2の画像 2
    • Unscrew the 3mm phillips head screws along the motherboard using a HH0 screwdriver.
  13. Acer Iconia W3-810  Screen Replacement: 手順 13、 2の画像 1 Acer Iconia W3-810  Screen Replacement: 手順 13、 2の画像 2
    • Lift the retaining flap of the ribbon cord connecting the screen circuit board to the motherboard using a plastic opening tool.
    • Then, remove the ribbon cord from its slot using a plastic opening tool.
  14. Acer Iconia W3-810  Screen Replacement: 手順 14、 1の画像 1
    • Unscrew the 3mm phillips head screws from beneath the screen circuit board using the same HHO screwdriver.
  15. Acer Iconia W3-810  Screen Replacement: 手順 15、 1の画像 1
    • Unscrew the 3mm phillips head screws connecting speaker and home button circuit board from main frame using the HHO screwdriver.
  16. Acer Iconia W3-810  Screen Replacement: 手順 16、 1の画像 1
    • Pull ribbon cord from designated slots on screen circuit board.
  17. Acer Iconia W3-810  Screen Replacement: 手順 17、 1の画像 1
    • Unscrew left speaker from frame by moving the ribbon cord out of the way to access the 3mm phillips head screws.
  18. Acer Iconia W3-810  Screen Replacement: 手順 18、 1の画像 1
    • Loosen speaker cord from main back frame by breaking the tape seal using a spudger.
  19. Acer Iconia W3-810  Screen Replacement: 手順 19、 1の画像 1
    • Loosen the main back metal frame from the front casing using a plastic opening tool.
  20. Acer Iconia W3-810  Screen Replacement: 手順 20、 1の画像 1
    • Loosen metal tape from the front panel using a spudger.
  21. Acer Iconia W3-810  Screen Replacement: 手順 21、 1の画像 1
    • detach metal tape from the back of the screen using a spudger.
  22. Acer Iconia W3-810  Screen Replacement: 手順 22、 1の画像 1
    • Remove the screen from the front casing.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Adam Fierce
メンバー登録日: 09/15/16
418 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 18-4, Blackwell Fall 2016 USF Tampa, Team 18-4, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S18G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 33
今までの合計 2,232
